SOS
Old Nov 4, 2023 | 09:35 AM
gatorbait021's Avatar
gatorbait021
3rd Gear
SOS
Howdy gentleman,
First post. Stuck here in South Texas lol. Came to pick up 6.0 number 2 and so far no good.. But not terrible. 34,000 miles. 3,000 hrs. Service truck. F550. No numbers because I don't have my cord to my sct. Fully stock. No changes too the engine.
Cranks up, idles great. Backs up fine, rolls forward fine. If you get into the throttle it holds the gear until you let off then it will change.
while in throttle it will slowly pick up rpms and then fall flat for a half a second and then try to pick back up again.. In between that it barks bad.. when you let off throttle it barks as well.. has a wierd turbo sound as well.. more like a whine instead of a whistle but you can hear the whistle slightly.
Here sitting beside it because I have knowhere else to be lol, I may be a texas resident soon if this isn't fixed lol. Has 0 blow by. Brought to part store and no codes beside a abs light that came on while I was headed up there
Old Nov 4, 2023 | 09:42 AM
bismic's Avatar
bismic
I don't think parts store code readers are all generally that thorough, but I understand that that is all you can do.
What city are you in?
Old Nov 4, 2023 | 09:54 AM
gatorbait021
3rd Gear
Donna, all the way at the bottom lol. And called ford here but they don't answer
Old Nov 4, 2023 | 10:01 AM
bismic's Avatar
bismic
It is not going to be possible to diagnose with any confidence without a good scan tool and code reader.
Sounds like it easily could be a stuck turbo.
That said, try disconnecting the EBP sensor and the ICP sensor to see if that helps any.
Also, look for CAC leaks, MAP sensor hose leaks, plugged up MAP sensor hose or plugged nipple (for the MAP sensor hose) on the intake manifold.
If you are going to own 6.0L's, you need a good scan tool - ForScan Lite is the best ( AND the best value), unless you get the full version of it on a laptop.
A MacAllen dealership should be able to help you, but that is a tow bill I guess.
Old Nov 4, 2023 | 10:16 AM
gatorbait021
3rd Gear
OK thanks I'll call.
Old Nov 4, 2023 | 10:25 AM
bismic's Avatar
bismic
Do the easy things I suggested first.
Stewy16
Sep 15, 2022 11:10 AM
jeffdoerr
Aug 4, 2018 09:06 PM
BillyBob69
Mar 2, 2011 08:02 PM
boulderbronco
6.4L Power Stroke Diesel
Jan 4, 2008 12:40 AM
15 and 92 Dad
23
Apr 28, 2007 03:29 PM
