Engine chugs after letting off throttle
Old Aug 31, 2022 | 08:36 PM
Stewy16's Avatar
Stewy16
8th Gear
I have a 2000 f250 7.3 with stock injectors and turbo and hydra tune done by a local shop. When I step on it pretty good on performance tune and then after I let off the throttle it chugs like it’s about to die. I don’t think it’s a turbo fart. It’s more like the engine feels like it’s about to die. It idles normal after 5-10 seconds.
also the power doesn’t seem to come on very quick compared to some issues of my friends trucks with similar build.
any ideas on what is causing that would be great.
Old Aug 31, 2022 | 09:39 PM
RacinJasonWV's Avatar
RacinJasonWV
Hi Stewy and welcome to the forum.
I’d start by getting a way to monitor ICP. Look in the tech folder sticky thread for an entire section on FORScan.
https://www.ford-trucks.com/forums/1...ch-folder.html
Throttle tip in feel can vary greatly depending on your setup. What all has been done to the truck? Stock turbo?
Leaky uppipes would be a first guess along with potential boost leaks. Either of those will kill performance. But first let’s get this off throttle stumble sorted out.
Old Sep 1, 2022 | 12:33 AM
Stewy16's Avatar
Stewy16
8th Gear
I’ll look into monitoring ICP. I’m new to diesels altogether so I’m trying to take it one step at a time. Is there an obd2 scanner you suggest? I am wanting to build up this truck to be a good tow and daily driver.
I put a new stock turbo in a few months ago and I don’t seem to be having boost leaks but I will check that.
I’ll try to add a video of the truck doing what I described in the original post.
Old Sep 1, 2022 | 02:41 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Best combo these days to read codes and monitor sensors is the FORScan app on your android device plus an OBDII adapter,
cheap cheap
if you're lucky or https://www.obdlink.com/products/obdlink-lx/ if you want tools to work w/o question.
When you replaced the turbo did you put in new up pipes?
Few better trucks for tow and DD duty, good choice! Well worn pathway of mods for that service and everyone here can help.
Pics of the new rig always gets folks excited.
Old Sep 1, 2022 | 07:17 AM
FordTruckNoob's Avatar
FordTruckNoob
I agree with the others on the need to log ICP. Once you have data, plug it into PID Charting Tool found in the stickies at the top of the forum.
My initial guess without details that you have a sticky IPR.
Old Sep 1, 2022 | 09:50 AM
RacinJasonWV
My initial guess without datais that you have a sticky IPR.
That was my thought as well but I was trying not to be too bold with my guesses. Two goobers agree so it must be true.
Old Sep 1, 2022 | 10:33 AM
Stewy16's Avatar
Stewy16
8th Gear
I will probably just get the good OBDII connector. I hate buying crap they may or may not work right. Also, I don't have any android devices. Is there something that will work on IOS or should I just go with a laptop configuration?
Im headed out of town for the weekend but will try to get some vehicle data together next week to share as well as some pictures.
Thanks all.
Old Sep 1, 2022 | 10:46 AM
Stewy16's Avatar
Stewy16
8th Gear
Old Sep 1, 2022 | 12:44 PM
RacinJasonWV
I ordered this one for use with iPhone. It’s not been connected to the truck yet but does work with my other vehicles using their included app. I had plans for this which included leaving connected to one of my vehicles which is why I opted for the more expensive model. This one sleeps and does not drain battery.
OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows https://a.co/d/j5a8z53
Old Sep 1, 2022 | 04:40 PM
Stewy16's Avatar
Stewy16
8th Gear
Can I get Icp reading on my edge insight cts3?
Old Sep 1, 2022 | 04:42 PM
RacinJasonWV
Yes.
I think there’s even a way to save a data log, which may be plot-able, but I’ve never done it.
Old Sep 11, 2022 | 10:57 PM
Stewy16's Avatar
Stewy16
8th Gear
Replaced some parts
Replaced Icp ipr ebp tube and sensor and wires in a new plug to the driver side valve cover harness. Issue went away. It also feels like I’m getting more low end power. I wasn’t able to run the truck and record icp but there was a code that indicates fault on icp.
now I’m going to replace up pipes to see if I can get egt down a bit. And starting to think about some more clean up I can do to make it even better.
Old Sep 11, 2022 | 10:58 PM
Stewy16's Avatar
Stewy16
8th Gear
Transmission shifts better
Replacing those parts has also smoothed out my shifts a ton. The ebp tube had some huge holes in it. I’m guessing that was part of the problem.
Old Sep 12, 2022 | 01:33 AM
aawlberninf350
It's a Van Gogh
Those parts count for 93.6% of a well running 7.3, so you nailed it brudda!
If your uppies are OEM they need to be replaced.
Old Sep 15, 2022 | 11:10 AM
Stewy16's Avatar
Stewy16
8th Gear
Seems like everything was just about perfect for a week. Went out this morning and the truck wont start. Scan tool is scheduled to get here in about a month so that wont help me today. Feels like the truck is building up pressure like its about to start and then looses it and then empty cranking. Could this be Cam Position Sensor issue? Seems like when I fix one thing the weak link shows up. somewhere else.
20Platinum01
Jan 25, 2009 08:46 PM
stroke-of-luck00
Dec 14, 2008 08:56 PM
justice
Mar 20, 2008 07:20 PM
15 and 92 Dad
23
Apr 28, 2007 03:29 PM
