Purolator fuel filter
Old Oct 30, 2023 | 04:15 PM
tradosaurus's Avatar
tradosaurus
Anyone use the Purolator fuel filters vs the Motorcraft?
Purolator Fuel filters
Old Oct 30, 2023 | 05:18 PM
Dirthawg2.0's Avatar
Dirthawg2.0
Fuel and Air filters are the two items that need to be Motorcraft on these trucks. I wouldn't risk it to save $30 on a fuel filter set. There has to be a reason that Purolator filter is much cheaper.
Old Oct 30, 2023 | 07:29 PM
senix's Avatar
senix
dont do it. not worth the save a few bucks.
Old Oct 30, 2023 | 08:44 PM
Overkill2's Avatar
Overkill2
When I emailed Donaldson about their filters, I believe they stated that their primary filters do not contain the water separation film, for lack of the proper term at this time, or the internal valve in the secondary filter allowing the system to be primed and allowing air to be bled off... I'll try and find that email...
But x2 on sticking with the Motorcraft fuel filter set.
Old Oct 31, 2023 | 06:11 AM
rufushusky's Avatar
rufushusky
Obviously with a 2019 I have even fewer aftermarket options... but nope, don't do it. Not worth it, IMHO. When I had a 2004.5 Dodge, the Purolator fuel filter was 18 microns, no water stripping rating... the OEM spec was 7 microns and honestly that application really need a 5 micron or less fuel filter with the rates 3rd gen dodges ate fuel injectors.
Old Oct 31, 2023 | 06:28 AM
tradosaurus
Called the local Ford dealership parts dept. For the two Motorcraft fuel filters and and oil filter the cost is $180. I normally support local business if the price is close but not this time.
I will just buy the set at dieselfiltersonline.com. for $102
Old Oct 31, 2023 | 06:33 AM
rufushusky's Avatar
rufushusky
Ouch, I didn't realize the 2011-2016 were more expensive than the fairly expensive 2017+ fuel filters. Sheesh.. really makes you think about grabbing a pair of FB1311's....
Old Oct 31, 2023 | 07:14 AM
JoeUser's Avatar
JoeUser
That extra little hose clip is mighty special, that's likely the culprit. The 2017+ don't require it, so you save $20 a kit...
Old Oct 31, 2023 | 08:42 AM
Overkill2's Avatar
Overkill2
That part number set includes a 2124 oil filter...
https://www.dieselfiltersonline.com/...rucks.html?p=2
There's 3 different (part numbers) listings for the newer trucks. Since I don't have one... Don't know difference nor care...
Old Oct 31, 2023 | 08:53 AM
Overkill2's Avatar
Overkill2
From my post on the fuel filter question thread...
Copied and pasted...
Seems Rock Auto is the cheapest.
☝☝ now in stock...
checked Rock Auto and they don't have the OEM filter set listed... they did this summer when I last checked...
Diesel filters online has them for $76.95
Village Ford Parts has them for $86.13 so that means the dieselfiltersonline price is good price... with a list price of $132.71.
There's also this
5 pack 5 pack
5 pack 5 pack
on Amazon which works out to $62.90... what I like about it is that it has an OEM sticker on the box. They appear to be the real deal.
cpobst
Jul 2, 2022 08:28 AM
chadjones99
Jun 23, 2022 08:13 PM
Longdistancetrucker
Modular V8 (4.6L, 5.4L)
27
Apr 3, 2012 07:01 PM
stevestroke01
Jun 27, 2011 10:38 AM
61 uni
Nov 22, 2008 08:20 AM
