The Fuel Filter Debate
Old Feb 18, 2012 | 04:05 PM
Longdistancetrucker's Avatar
Longdistancetrucker
Just wondering what everyone thinks is the best fuel filter brand?
Old Feb 18, 2012 | 05:12 PM
galaxie641's Avatar
galaxie641
Use Wix/Napa Gold for pretty much everything.
Old Feb 18, 2012 | 06:23 PM
nyskills's Avatar
nyskills
While you all may "enjoy" using aftermarket filters, ford reccomends motorcraft for a reason!
Old Feb 18, 2012 | 10:27 PM
go_phx's Avatar
go_phx
Yes, because they don't make money if we buy Napa filters.
Old Feb 19, 2012 | 10:10 AM
galaxie641's Avatar
galaxie641
Exactly, if anything they would encourage us to use the "evil" "bad" filters because they would make more money from all the repairs we would obviously need from all the ruined engines.
We use wix on $100K tractors I have no issues using them in my $10K car or truck.
Old Feb 19, 2012 | 10:17 AM
nyskills's Avatar
nyskills
That is untrue. Ford Recommends motorcraft because the vehicle (including the engine) is engineered to work with genuine ford parts, and is designed to be repaired by qualified Ford technicians.
Old Feb 19, 2012 | 10:45 AM
Longdistancetrucker
I guess your getting ripped off when it comes to vehicle maintenance.
As with any vehicle, engine, component, ect... the part needs to be functional. It is a fact that motorcraft is nowhere near the best. There are filters that can filter out particles half the size than what motorcraft can.
You are aware that there are also aftermarket parts that ford has approved. Even when it comes to fluids, I've never put motorcraft oil, in my engine. While I do meet the specs they specify, virtually every other oil is better performing than motorcraft. And I'd be willing to bet you that 99% of ford service techs don't even put motorcraft oil, (or motorcraft parts for that matter) in their personal vehicles.
Not trying to sound like an ***, but do some product comparisons and you will easily find that there are a ton of products out there that outperform motorcraft.
Old Feb 20, 2012 | 08:18 AM
JWA's Avatar
JWA
Also have to gently disagree with this ^^^ as an all-inclusive statement. While its true SOME MotorCraft or Ford OEM parts somewhat out perform aftermarket items this is hardly the case all the time. Sensors are a good example where MotorCraft seem to be best items as reported here time and time again. Too many have tried using Bosch or others, creating performance and MPG issues quickly cured by switching back to Motorcraft.
It's likely Ford's spec's need to be observed but its also likely the MotorCraft-branded items aren't of the absolute best quality. I learn what's best for most applications by reading the real-world experiences of those here in FTE's forums---nothing beats hands-on advice IMHO.
Ford stealership mechanics really aren't any better due where they work or what uniform they wear. While they might have access to Ford's factory information and such any other qualified, dedicated quality-conscious mechanic is at least as good. Stealerships are all about making money, assume you'll be back "just because". In the case of warranty repairs they're unavoidable yet over and over we hear horror stories of bad experiences. The key to good repairs is shopping around, talking to others who'll enthusiastically recommend their own trusted mechanics. This is a great way to find someone reliable, fair-priced and above all else competent and knowledgeable!
There's a wealth of info here---use it to your advantage!
Old Feb 20, 2012 | 11:05 AM
Longdistancetrucker
Very Well Said
Old Feb 20, 2012 | 04:02 PM
acf6's Avatar
acf6
I put in a new motorcraft fuel filter yesterday
Old Feb 22, 2012 | 06:23 PM
4x41977's Avatar
4x41977
I go motorcraft on most things. I have an 03 f250 and still has the original battery and checked the radiator fluid the other day and still checks in to atleast -45 F. Where the gauge topped out.
Old Feb 24, 2012 | 12:55 AM
hodges710's Avatar
hodges710
Napa for one is a scam shop, they buy the same items that your smaller shops can get but charge way more money. I dont care what someone decides to use for a filter or any part for this matter, just stay away from Napa.
Old Feb 26, 2012 | 01:01 PM
CHEMMANN7411's Avatar
CHEMMANN7411
hey all can somebody tell where my fuel filter is on my 2011 f-250 xlt s/d fx4 6.2 gas
Old Feb 26, 2012 | 01:27 PM
acf6's Avatar
acf6
not sure where it is in your 6.2.. on the 5.4s, its on the driver side frame rail, on the inside, about right before the transfer case
again, this is for a 5.4, so it could be/probably is different but this is what the 5.4 fuel filter will look like
Old Feb 26, 2012 | 01:57 PM
critterf1's Avatar
critterf1
I believe the fuel filters in the new trucks are in the gas tank.
