Speedo question
Old Oct 27, 2023 | 05:22 PM
Roady1269's Avatar
Roady1269
Speedo question
Can a 92-96 obs ford truck start and run with no speedometer plugged in?
Old Oct 28, 2023 | 05:13 AM
manicmechanic007's Avatar
manicmechanic007
Sure, you can drive those with the instrument cluster out.
Old Oct 28, 2023 | 07:33 AM
Eddiec1564's Avatar
Eddiec1564
Till the battery dies as the instrument cluster does control alternator charging.
Old Oct 29, 2023 | 09:40 AM
C6Scott's Avatar
C6Scott
another issue you may have without the PSOM is hard shifting or shifting at the wrong times as the PSOM puts out a signal that is a factor in operation of the OD Auto transmissions. Shouldn’t affect starting and running though. Driving is a different story.
Old Oct 30, 2023 | 05:02 PM
manicmechanic007
Well, the question was will it start and run
And yes, you can pull the cluster out and drive the truck
Out of the shop then back in when the fixed cluster returns for instance
We used to send those out constantly for warranty repair
Old Nov 4, 2023 | 08:32 PM
Roady1269's Avatar
Roady1269
Ok, it starts and idles fine, even revs smoothly. As soon as I put it in gear, speedometer bounces, starts to cough and tries to stall and runs like crap. I have a different speedometer I want to install. I hope that will cure my issues.
Any thoughts or suggestions?
Old Nov 5, 2023 | 04:23 AM
manicmechanic007
Not sure what I'd do yet
Not enough info
What year is it?
What happens if you unplug the TRS or MLP and then put it in gear?
The new cluster might help
I am a big find the code and diagnosis man
Not much for part replacement until a few hoops have been jumped through
I do throw parts at them like everybody else when stumped (rather amusing chasing your tail sometimes)
Old Nov 5, 2023 | 01:43 PM
Roady1269's Avatar
Roady1269
Not enough info
What year is it?
I'm sorry, its a 1993 Flareside 4x4, 302 auto.
I have no idea how to pull codes or what TRS or a MLP is. I am going to put my new (to me) speedometer in today.
Old Nov 5, 2023 | 08:49 PM
manicmechanic007
No need to be sorry but thanks
Difficult to pull codes on the older pre OBD2 cars and trucks (your 1993)
You will need an Innova scan tool or another tester or you can use a paperclip (with some knowledge and gumption)
TRS (Transmission Range Sensor) is the new term for neutral safety switch as is the MLP Manual Lever Position sensor
Both bolt to the transmission where the shift lever goes, tells the processor which gear you have selected
Sounds like a nice truck
So, unplug the trans connector on the drivers side and see if it still runs or if it shifts okay
I am not certain or sure the cluster controls the field on your alternator
Maybe check it with a DVOM and see what the voltage is at the battery with the engine running and the cluster disconnected
Old Nov 5, 2023 | 09:22 PM
Roady1269's Avatar
Roady1269
My problem child....
Old Nov 5, 2023 | 09:32 PM
AuroraGirl's Avatar
AuroraGirl
codes? any?
Old Nov 6, 2023 | 04:50 PM
Roady1269's Avatar
Roady1269
Replaced the speedometer and it fixed ALL my issues. Runs great, shifts great, and idles great. Who would have thought the speedo controls so much.
Thank you everyone for the help.
Old Nov 6, 2023 | 06:40 PM
rla2005's Avatar
rla2005
Thanks for the update.
Aussie BrianB
Australia Chapter
41
Jul 27, 2013 09:53 PM
Aquik72
Jun 7, 2010 09:25 AM
jav409
Nov 21, 2005 08:22 PM
