The winter tires for our 01 are 215 / 85 / 16 ... a bit smaller than the stock 265/75 tires. It's fun though, you can now go faster and not get in trouble!
You don't have to. The difference is probably not that much, and it is easy to calculate. 5%? 10%? It is not that big of a deal if you plan to run the tires short term. If you plan to run them long term, your dealer can adjust the speedo for you. That will probably cost you $100. If you plan to switch back and forth between tires depending on the season, it is best to keep them approximately the same diameter.
(and no, I will NOT adjust your speedo for you, I don't care how tight it is)
