MLPS Part # Compatibility
Old Nov 6, 2023 | 01:46 PM
91bird's Avatar
91bird
Trailering
My 1995 F350 7.5 E4OD has part number F5TP-7F293-A_ on the MLPS (connector pointing up to the sky). The _ is due to the housing being scratched and I can't see if there is a letter in the 11th place or not.
What would the replacement part number be? I'm not able to track a replacement in the Ford system. Local Ford parts department said the replacement is F5TZ-7A247-B but it's not available.
Is the correct replacement number F7TZ-7F293-AA? I'm not able to trace the part number back to my current part of F5TP-7F293-A_.
Old Nov 6, 2023 | 02:01 PM
R&RFord's Avatar
R&RFord
Ford doesn't typically put part numbers on parts. But they do like to put engineering numbers on parts. The 2 can be cross referenced by Ford parts people, but when they revamped the parts database some years back they lost a lot of data for these older vehicles.
The last digit on the code was an A. The part number provided by the dealer is the correct replacement. It is unobtanium as far as I can tell.
Pick your poison on aftermarket.
Old Nov 6, 2023 | 06:52 PM
JJF20's Avatar
JJF20
I looked a couple yrs ago, I couldn’t find an oem or nos anywhere. Might have luck on eBay. I used an aftermarket.. can’t remember which, it’s working fine.
FYI, You can also get the harness side pigtail aftermarket if need be.
redhaw
Aug 30, 2022 04:10 PM
GeneGregory
18
Nov 11, 2016 08:40 PM
FARM69
Feb 8, 2010 11:05 AM
SC_Dave
Jul 28, 2009 03:13 PM
bobpat204
Jan 7, 2007 12:53 PM
