My Truck May Have Met Its Match...
#46
He decided not to fight it because he knew he was way overweight according to the door jam sticker.
Furthermore, his neighbor, who is an attorney, told him he would be up the creek without a paddle if he ever got into a wreck using same truck/trailer combo after already being ticketed.
He solved it the easy way. He traded in the 250 on a 350.
The following users liked this post:
#47
yep, and I would have hired an attorney who is smart, and broke down spec by spec an f250 to an f350, amd furthermore, compared the sterling 10.50 axles to a 2016 f350 which uses the same and has a payload of 3600lbs and a weaker frame and suspension. Then I would counter sue the **** out of them. If its unsafe for a f250 then it's unsafe for an f350, if an f250 can't stop it then an f350 can't. The reason a f250 was created was just for states on registering purposes.
Why go to the trouble to buy a 250 and put up with the hassle?
#48
agree, but alot of folks buy used, an an f250 is more readily available. I wouldnt rule it out over something this dumb, if time and place comes, you can prove the f250 vs. F350 spec by spec and see if one can't do it neither can.
#49
overload
Hey did see the picture of the dodge truck that broke his frame because his payload was over his limit. https://www.thedrive.com/news/broken...ad-a-big-truck
You have a f250 and you payload does matter. You need to know your pin weight. You said 40 feet long, I would think dually for that. Have you had it on the scales fully loaded? I think that will answer the questions.
Things that can help
air bags
heavy duty(350 450 springs)
Axle change to dually.
#50
I'm moving on up, to load range "F"
I just received my next set of tires for my F-350 SCLB 6.7 Lariat and they are 33"x12.5" x 20" Load range "F" 12-ply. My truck has the optional snowplow/camper and 11,400lb GVWR packages and I have the Air Lift 7500XL bags. I'm running the OEM Michelin A/S 275/65r20 load range "E" tires at present with 42k mi on them.
My goal with this combo is a smoother ride with my four LED headlights not in oncoming driver's eyes. I'm running 65psi all around towing an 31' toy hauler with a 1060lb hitch weight and 11,400lb GVWR. Loaded with two street bikes and 100 gallons of water and I'm sure that it's loaded down. Add to this whatever is in the b. Ied and cab of the truck. I'm glad that I upgraded the hitch to a 14K Equalizer Load distributing hitch.
#51
The following 4 users liked this post by Ltngdrvr:
#52
The following 4 users liked this post by Y2KW57:
#53
air bags
air bags
The following 2 users liked this post by senix:
#54
#55
I don't want to fix anything - I hope to give you an option so you can continue to tow stuff like that big fat toy-hauler comfortably and make more money. As was mentioned before, buy one of these water bladders and lay it on the floor in the toy hauling area. Cheap, portable, light, easy to stow when not in use. Fill it with water and it will give you up to 2,127 lbs. behind the axles, reducing the RV pin weight. Drain it at the destination and throw it in the bed. Since you aren't using it for drinking out of you don't even have to worry about cleaning it like an RV user does. 264 Gallon Water Bladder
![Spanking](images/smilies2/spanka.gif)
#56
they can give a ticket for anything. Doesn't mean its correct. I have gotten a ticket for fuel decal, I mailed in is false and i wasnt paying, and he didn't verify my weight so it was false. Never had to pay it.
For him all he needs to do is mail in he not paying, and day they didn't verify weights for those assumptions. If they did weigh him, ask them to prove how it's over weight, and the axle and tires specs.
#57
Plus, as far as I know, the company only has that one big toy hauler, so I will just pass on the jobs where it would have to be picked up.
#58
![](https://cimg7.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/491x391/eagle1165_781da6298fb835098be52d89cc2b1053bbad2814.jpg)
air bags
air bags
#59
#60
The following 3 users liked this post by BSHORT:
