a/c issues
Old Oct 2, 2023 | 09:32 PM
bwguardian's Avatar
bwguardian
a/c issues
We bought back our middle daughters Ford Edge...long story...and have had it up and running since the middle of the summer. I know it's not an F series like our other 2 trucks but there are some good folks on here that are more versed than I on this subject. The a/c has been cooling fine at 45*-48* vent temperature depending on outside air temperatures...it's been hot. Sunday we drove the car and everything seemed okay on the short trip to and from church. So a couple hours later we get in the car to go get our youngest daughter and immediately notice the a/c blowing warm air. I cycle the a/c system on/off and my wife noticed in the beginning there was a short burst of cold air before going warm. I hook up Forscan to check DTC codes and there's nothing related to the a/c system. I also did the KOEO self test and the fans powered up, then the compressor clutch engaged. I hook up a set of gauges and the high and low side were near 0 with engine off. So I jump the compressor clutch relay while the engine is running and get a reading of -20 on the low side and +20 on the high side. I'm confused about this and looking for insight...
Old Oct 3, 2023 | 06:58 AM
udsuth78's Avatar
udsuth78
Not being familiar with that particular setup I'm not sure but from the sound of it you've got a blockage in the system, but that doesn't explain the 0 psi gauge readings. Either way here's a bump hoping someone more helpful stumbles across the thread.
Old Oct 3, 2023 | 07:10 AM
bwguardian's Avatar
bwguardian
I forgot to mention that when we got back home from getting our youngest daughter I noticed the compressor clutch was engaged when the a/c was on but the refrigerant line coming off the compressor was not cold. I also checked it the next morning after sitting all night and that's when the compressor clutch would not engage when turned on.
Old Oct 3, 2023 | 09:46 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by bwguardian
I hook up a set of gauges and the high and low side were near 0 with engine off. ..
Resting pressure needs to be at least 50 psi. You have a freon leak somewhere.
Old Oct 3, 2023 | 10:23 AM
kbeefy's Avatar
kbeefy
Low charge. Evacuate, Leak test, repair, vacuum and recharge.
cardsfanbj
1983 - 2012 Ranger & B-Series
15
Jun 22, 2016 04:02 PM
codyop
Jul 29, 2015 08:11 AM
maximusfd
Jan 21, 2014 09:53 PM
krewat
Aug 22, 2005 08:22 AM
FLRanger
Jan 4, 2005 03:11 AM
