a/c
Old Jan 4, 2005 | 12:15 AM
FLRanger's Avatar
FLRanger
a/c
i have a 96 ranger 4 cyl mtx. the a/c compressor seems to be continually cycling in short rapid stints. a/c is still blowing cold air what could this be?
Old Jan 4, 2005 | 12:55 AM
AlfredB1979's Avatar
AlfredB1979
Look in the Haynes manual (if nothing else, you're buying "like yesterday" one to catch up with us) and it will list on page 6-11 (emissions section) all the switches and relays you need to comb through.
The A/C wide open throttle relay in the relay box should be in good shape, the cycling pressure switches need to be checked and, of course, the compressor clutch needs looking over.
I had that same clicking when my clutch went toast. You won't have cold air for long in that case.
O'Reilly has that for about 90 bucks and an hour of labor at a shop (they need to be shimmed properly and pulled with a special tool) will take care of you if the clutch is the case.
Old Jan 4, 2005 | 03:11 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!!
I'd begin by hooking up gauges to the system and evaluate the charge; however this depends on the climate where you are at. If it's a cool day and you are running a/c with the fan on low, expect some cycling as this is normal. On a warm day, it should not cycle. Also, short-cycling is common on a winter day when the defroster is on. Defrost turns on the compressor to dehumidify the air yet very little heat needs to be removed from the incomming air to accomplish this.
What's the ambient temp like where you're at and how long is the compressor engaging? This could be nothing more than a little low on charge.
