Hi fellas I recently scored a 2000 f350 super cab long bed 4x4 7.3 auto it has esof electric shift on the fly 4x4 the shift motor still works when you jump the solenoid under the hood all fuses are good but there is no power to the switch in the cab at all no even the illumination circuit works I really don't want to tear the dash out to chase wires anyone got any advice btw still use the 4x4 every day as I live 5 miles up a Nasty dirt road also if I don't get back in a timely manner I cause I'm off grid and probably haven't had internet
The lights burn out, as it only an incandescent. How do you know you have no power? Have you checked fuses and the switch for continuity? What about vacuum lines to the hub, they should probably be replaced.
Try the simple stuff first.
Get rid of that problematic over complicated garbage and put a manual shift transfer case in. I will never understand why manufacturers want to complicate something as simple as shifting a transfer case, a lever and a linkage is the only way to go.
Hi guys sorry for the late reply I'm going to switch to manual 4x4 but FYI I pulled the switch out and checked the Plug for power there was no power and all fuses were good
are you Off Grid so far that a T-Mobile cell tower can't reach you?
I have two TM hotspots and they work just about everywhere we carry them.
I have one here at home, and my daughter carried the 2nd one with her to visit family up in Price, Utah... it worked the whole way up there.
I used it last summer in Price, and got good speeds of 25 to 80 mbps down
the DATA rate is $50/month for 100gB/month
I paid $198 for mine in advance, saved a few coins.
this is a later version of mine which is a m2000, I have seen speeds on of 800mBps in a good location.... wireless is the same a Real Estate, Location, location, location.
but, even in bad areas, they have been good enough for our laptops
I have T Mobile and was completely out of range today for an hour driving thru the Delta. California is huge and has dead spots the size of some states.
For the power to the switch inspect the wire harness down to the trans, things get crimped and mangled.
If desperate you can pull off the xfer switch motor from the case and shift it with a crescent wrench. Put it back on if dust is an issue.
I got tired of chasing vacuum leaks (and replacing wheel hubs) so capped the vacuum line, put an NPT plug in each knuckle, installed a Dynatrac Free-Spin kit, and never looked back.
That is a little on the extreme end price-wise but I had just done over $1200 worth of damage to the front drivetrain in parts alone so I considered it a "discount" towards the price of the kit. YMMV
I have waren 9 1/10 turn lovers with steel slugs it an electrical issue if I jum the solenoid for the 4x4 with a wire and lock the hubs it works I was hoping it would be easy to fix but it's not so I'm gonna convert to manual 4x4
if I jump the solenoids under the hood I will shift a lot easier than climbing under it and changing gears with a Cresent wrench I think that the wires for th switch in the cab may have been messed with by some installing aftermarket lights and stereo
The vacuum hubs suck, but if you just treat them like manual hubs they work fine.
I've had my ESOF for 16 years now and it's never failed, not sure where the hate is coming from.
The switch is just a series of resistors that the GEM module uses to determine what you want the TCase actuator to do.
Measuring for voltage there won't help you. You should check for voltage at either the shift actuator or the 4x4 relays on the firewall.
To be clear, you can't shift from 2x to 4x high, right?
