Should I Flash?
Old Nov 24, 2003 | 12:47 PM
  #31
emtabmm's Avatar
emtabmm
Originally posted by Tower Jack
The service advisor said Ford ordered a reflash and they were gonna do it no mater what I said.
All I can say is client beware. It is your truck. Period. Ford can not and will not insist that anything be done with out your approval. Even recalls. It is your choise. You are the client and the boss. At least at our dealership.
Old Nov 24, 2003 | 12:55 PM
  #32
Tower Jack's Avatar
Tower Jack
oh ya, it read the following mods have been made
PCM, FICM, &TCM Repro
Part # 3U7A-12A650-FTA You got me on this one?
Old Nov 24, 2003 | 01:08 PM
  #33
emtabmm's Avatar
emtabmm
That part # is just a reference for the labor operation of reprogramming. Part quantity should read zero.
Old Nov 24, 2003 | 03:59 PM
  #34
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally posted by emtabmm
Build date can be found on the drivers door info sticker at top...
03/03, so by all that I read it is a bad onne.......hum
by everyones standard
Old Nov 24, 2003 | 04:03 PM
  #35
IB Tim's Avatar
IB Tim
You got BS’ed at the highest level, you own it you pay for it, YOU say what happens.
PERIOD
Old Nov 24, 2003 | 04:24 PM
  #36
IB Tim's Avatar
IB Tim
Is this the chassis or motor or combo of both...build date?
Old Nov 24, 2003 | 04:43 PM
  #37
redstar's Avatar
redstar
Thumbs up
I flashed approx 3wks ago and the dealer changed to 5w-30 oil which I questioned but that is Ford recomendation. The flash cured rough idle problem and the hesitation on initial acceleration. It also restored the loss of power from the first flash so I am satisfied.
Old Nov 24, 2003 | 04:48 PM
  #38
emtabmm's Avatar
emtabmm
Tim, that is the chassis build date, on the back side (firewall side) of the valve cover is where you will find the engine build date. On the white cap of the fuel injector you will find the part # for the injectors, see if they are all the same and email the # to me, I can find out if they are a problem or not for you...
Old Nov 24, 2003 | 07:06 PM
  #39
IB Tim's Avatar
IB Tim
OK this is turning out ot be tuff and it should not be.
The drivers side valve cove has a sticker on it that has (18-MAR-03) could that be it. If not where?? can you see where or do you need a mirror.
Now on to the injectors............cannot even find one or maybe I am not looking in the correct place. Is the injector in the head, (port injection) or is it on the manifold???
I have had my *** in the air, under the hood for so long my knees now have the imprint of the radiator support. How in the world did Monaca do it for so long?
vin 1FMSU41P73EC70930
Also there is a date, on the rad support that has been hand written with a felt tip pin 4-19-03 weird because it does not look factory at all. Very neat and very intentional.
sure would like to have any and all info available.
Old Nov 24, 2003 | 07:12 PM
  #40
IB Tim's Avatar
IB Tim
Andy forgot something the hand written date had PDI in front of it.
Old Nov 24, 2003 | 07:45 PM
  #41
Tower Jack's Avatar
Tower Jack
After letting the truck sit outside for about 8 hours in 10 Deg F temps it started a lot faster now, ie before flash, turn over about 4 seconds, after flash about 1.5
Old Nov 25, 2003 | 05:53 AM
  #42
emtabmm's Avatar
emtabmm
Tim, pdi stands for predelivery inspection, the date is when that happened. March 18,2003 is the engine build date. The injectors are of the batch that Ford has had problems with. Tim, are you having any issues with the way the truck runs? Let me know....
P.S. Injectors are in the head...
Old Nov 25, 2003 | 06:22 PM
  #43
DeepBlue's Avatar
DeepBlue
Gents,
I was a computer programmer for years and I currently run a technology company, so I know about what I speak. Much like your "Windows Update" on your PC, each new flash will fix some problems and cause others. Each subsequent flash version will fix more and more problems and introduce fewer and new problems. The best flash version for this motor will be the last version before it goes end-of-life. Therefore, I will combine that advice the advice of several of the above posts: 1) If it is running OK, leave it alone for now. Next year, probably second quarter, I will go in and have it flashed to the latest level. In all likelyhood, the software will be reaching a state of maturity by then and most of the new problems will be gone.
Old Nov 25, 2003 | 06:24 PM
  #44
emtabmm's Avatar
emtabmm
Amen and it's over....
Old Nov 25, 2003 | 06:25 PM
  #45
IB Tim's Avatar
IB Tim
most interesting, and logical
