boost reading question
Old 09-21-2023, 03:36 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
i noticed something in my charts normally my map at idle is 100kpa, but it goes up to 190kpa, which is 27psi. However, I blew a hose. I took a picture of that and it was reading 299kpa. I was foot to floor for that. Does that mean I'm overboosting since it's 43psi, or should i be subtracting 100 atmospheric when trying to get boost pressure, so it would be 28psi plus atmosphere?
Old 09-21-2023, 05:43 PM
FiveOJester's Avatar
FiveOJester
FiveOJester is offline
Looks like the MAP you are reading is in absolute pressure since you're seeing about 100kpa at idle (~14.5psi) which matches your baro. To get boost you subtract the barometric pressure. So your worst case would be 299 - 100 = 199kpa or 28-29 psi of boost so you are right where you should be.
I'm pretty sure there is a PID you can pull up in Forscan for boost so you don't have to do the math. And I believe you can get it in psi units instead of kpa, just select a different option from the list.
Old 09-21-2023, 06:56 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
Thanks, I will look for it
Old 09-21-2023, 11:10 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
Ok the clamps from sinister diesel, clamped to the max, on their boots, blow off. I compared to OEM and max clamp, has a gap. So the material is considerably thicker. But no go for me.
Driving down the road and mashed it. Pop!
Listor
16
06-21-2021 08:06 AM
Roasted7
11-05-2012 09:35 PM
cowmilker08
33
09-30-2010 03:01 PM
crack
33
09-20-2007 04:52 PM
ehumaui
09-29-2003 09:58 AM
Quick Reply: boost reading question
