Steering Stabilizer Maintenance
Old Sep 20, 2023 | 01:47 PM
350Recon's Avatar
350Recon
I was looking at the scheduled maintenance in the manual and did not see anything on steering stabilizer. I am thinking that maybe a 20,000 mile replacement or once a year if you drive more would be a good maintenance service.
It would keep the front end components from excessive vibration from a worn out shock. If you are running twin shock system you could probably double that.
I was just wondering what some of you think about adding this to the maintenance rotation.
Old Sep 20, 2023 | 01:57 PM
99powerstrokedF250's Avatar
99powerstrokedF250
I always just look to see if it's leaking, and check for play. Replace as necessary. I've had them go 20k, I've had them go 80k. Depends a LOT on the roads you drive on.
Old Sep 20, 2023 | 07:39 PM
Leardriver's Avatar
Leardriver
I unbolted mine and put on a Bilstein as soon as I got home. That was my maintenance program.
Old Sep 20, 2023 | 10:24 PM
350Recon's Avatar
350Recon
I am looking at the Bilstein 5100 single shock for the replacement.
Old Sep 20, 2023 | 10:25 PM
350Recon's Avatar
350Recon
I thought I would change them before they blow out.
Old Sep 20, 2023 | 10:30 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Mine was shot at 10k miles. I installed a FOX stabilizer. Much nicer!
Old Sep 20, 2023 | 11:58 PM
Charlie98's Avatar
Charlie98
I plan on swapping out both the shocks and the steering damper with Bilstein 5100's. It's crazy, but at not even 6K miles, the factory shocks are hosed...
Old Sep 21, 2023 | 06:34 AM
rufushusky's Avatar
rufushusky
I swapped mine, which I assume was OEM at about 85k with the Bilstein, along with changing out my shocks for KYB's. OEM shocks have gone WAY down hill in recent years.
Old Sep 21, 2023 | 06:48 AM
Summers22's Avatar
Summers22
I just did this on my 2019 and it's so much better than the wore out factory components.
Kevin Burroughs
Jun 8, 2021 10:37 AM
Buckeye71
May 24, 2021 12:37 PM
Whitetail2017
Jun 26, 2020 03:10 PM
64rarebird
Apr 4, 2014 08:26 PM
epos48
Feb 27, 2006 07:21 PM
