Steering Stabilizer shock?
Old Apr 3, 2014 | 08:27 PM
64rarebird's Avatar
64rarebird
Hi all just finished doing a 78/79 steering box swap in my 77 f250 highboy everything went very well with alot help from fellow fte users, i am using for now the push pull steering system, my question is do i need to install a steering stabilizer shock? just looks like there may be issues with a possible death wobble with such a large tie rod running from one side to the other? Does anybody have any thoughts on a possible shock to use or part number brands etc if needed
Old Apr 3, 2014 | 11:02 PM
Pickupmanx2's Avatar
Pickupmanx2
Steering dampners, or stabilizers are specifically valved for steering, you can't just throw a shock on there!
Mainly they are used with LARGE tires, 35" and up usually (for me) the long tie-rod running from side to side isn't the issue, slop in the steering system and worn parts are the most likely culprits.
What size meats are you running, and how is the health of the rest of your steering system?
I think I got my last one from NAPA.
Old Apr 4, 2014 | 12:32 AM
co425's Avatar
co425
Death wobble is cause by worn out parts and poor geometry.
Old Apr 4, 2014 | 07:16 AM
64rarebird's Avatar
64rarebird
Sorry i think i may have mis communicated I don't have any issues with death wobble was just curious if and what guys are using for steering stabilizers shocks. And yes I am quite aware the steering stabilizer shock is of its own design I am a licensed auto tech with over 20 years on the front end machine. I guess what i was looking for was possible part numbers and different mounting systems you may have used without having to dig through pages of my shop manual/parts books, any luck using the factory mounting holes?
Old Apr 4, 2014 | 07:24 AM
earthquake68's Avatar
earthquake68
Just look up the stock steering stabilizer for a '79 F150. That is if I understand you converted to the crossover steering. The drag link should already have a hole for one end, you just need the little cup bracket for the frame side. A single stabilizer is fine up to 33" tires. 35" and above you should really run a dual set up.
I make a dual set up that works fairly well. Here it is on another FTE member's truck. It just uses two stock shocks instead of one.
Old Apr 4, 2014 | 08:08 AM
78 PEB's Avatar
78 PEB
Im sure some of the lift kit companies have steer stab brackets available. Single and double.
Old Apr 4, 2014 | 11:04 AM
co425's Avatar
co425
Depending in the front end they come with the passenger side hole for a steering stabilizer. My dana 60 front has one and I run a Monroe brand steering stabilizer. It mounts to the tie rod, not the drag link. I have a bracket from wfo concepts to mount to my 1.5" tie rod.
You can kind of see the bracket in this picture.
Old Apr 4, 2014 | 11:26 AM
64rarebird's Avatar
64rarebird
Thanks for the pics, was looking at the truck last night and had me thinking if it might be possible to use the hole in the tie rod end and maybe the mounting bracket and hole on the diff where the power steering ram assit cylinder was?
Old Apr 4, 2014 | 01:44 PM
earthquake68
You could also just get the dual stabilizer kit for Chevy. It clamps to the tie rod and the axle tube. Three u-bolts hold it to each. Someone put one on Ka'Bluey and it seems to work pretty well.
Old Apr 4, 2014 | 08:26 PM
MeanGreen460's Avatar
MeanGreen460
Also make sure your track bar bushings are good and tight.
4EXTRDR
13
May 12, 2011 10:59 AM
Dutter
1983 - 2012 Ranger & B-Series
Feb 13, 2011 09:00 PM
audimaster
Jun 10, 2007 05:08 PM
epos48
Feb 27, 2006 07:21 PM
Billy McNair
Feb 25, 2003 04:30 PM
