Steering stabilizer and vibration
Old May 23, 2021 | 03:06 PM
Buckeye71's Avatar
Buckeye71
I have installed a dual steering stabilizer from kelderman with kelderman shocks and it seems like my steering wheel is getting some vibration is this normal after installing this? I can’t recall it doing it before hand but I could be wrong truck is a 2021 f350
Old May 23, 2021 | 03:50 PM
willynilly's Avatar
willynilly
did it drive fine before you put all that stuff on there. if so, why did you put that stuff on ?
check the center bracket as some people reported clunking and watch for oil leak from the bolts. read this thread https://www.ford-trucks.com/forums/1...oud-clunk.html
Old May 23, 2021 | 04:38 PM
Buckeye71's Avatar
Buckeye71
I put it on so the truck wouldn’t get death wobble down the road
Old May 23, 2021 | 06:13 PM
nitebreeze's Avatar
nitebreeze
I have Kelderman with Fox and no vibration. I dont think if everything is tightened up right you will get vibration from adding a dual steering stabilizer.
Old May 23, 2021 | 07:12 PM
Buckeye71's Avatar
Buckeye71
I experienced the bottom out sound one time and never even dawned on me that’s what it could be I have since took the kelderman off to see if it helps the vibration is definitely less the steering feels a little easier but when I took it off the bar that the shocks were mounted too I can push it up not sure if there should be slip on it at all
Old May 23, 2021 | 08:09 PM
Buckeye71's Avatar
Buckeye71
Should I be able to move the bar by hand? Up and down it will love side to side it won’t
Old May 23, 2021 | 08:27 PM
4wd6.7L's Avatar
4wd6.7L
The ends that Ford uses have some acceptable up and down play. There is a spring inside.
Found it, bellow is wording from one the Ford FSA's having to do with steering oscillation. If you are seeing more movement than stated here then you might have a problem.
NOTE: If inspecting the steering drag link and tie rods, by design there will be 1-2 mm of vertical movement when pushing on or rotating the drag link and tie rod ends. This movement is characteristic due to the internal spring design and parts should not be replaced for this normal condition. Refer to the WSM procedures in Section 211-03 for additional information.
Old May 23, 2021 | 09:59 PM
Norcalpr's Avatar
Norcalpr
Take that junk off. A dual stabilizer doesn't stop or fix death wobble. If you have death wobble, it's from worn parts or a crappy alignment. Simply replace the worn parts and do a proper alignment and it goes away...
A stock rig doesn't need a dual stabilizer. Even a rig with slightly bigger tires doesn't need one.
Old May 24, 2021 | 04:16 AM
Buckeye71's Avatar
Buckeye71
so you don’t think a dual steering stabilizer would help keep the front end tight and avoid dw
Old May 24, 2021 | 04:55 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Gee, why are there a bunch of people on here that have this set up ??
Old May 24, 2021 | 10:00 AM
GNR22's Avatar
GNR22
Good marketing and shiny stickers.
Steering stabilizers, single, dual or otherwise, are a band-aid fix for a larger problem. There is an inherent issue with the coil sprung Super Duty front end, stemming from loose tolerances and poor geometry. The positive effects of this are a soft riding, easy steering truck. The negative effects are obvious.
Old May 24, 2021 | 11:08 AM
Buckeye71's Avatar
Buckeye71
my thing is that Ford thought good enough to put one on that’s where the dual made sense to me but since taking it off I believe it drives better so now I’m back to is it worth to upgrade the stock one and if not how do you know when it goes bad and needs replaced
i don’t know much about this stuff so your guys help is great
Old May 24, 2021 | 11:13 AM
Norcalpr's Avatar
Norcalpr
No. When death wobble occurs, what happens when you hold the wheel tighter? It gets worse. Adding more stabilizers is the same as you just holding on tighter. Just fix the root problem of the worn part...
because everyone believes this misconception that more is better. Then they blame ford when there's vibration or other things going on like this guy has. Why not 3? Why not 10? Why not 20?
One is all you need. it's job is to smooth out the shock from road hits, not to stop death wobble
Old May 24, 2021 | 11:55 AM
Buckeye71's Avatar
Buckeye71
So when should you change out the factory stabilizer and are they all the same meaning will a bilstein be as good as a fox and so fourth
Old May 24, 2021 | 12:37 PM
Norcalpr's Avatar
Norcalpr
Change it whenever it leaks, or if you feel like you're getting too much road feedback. They're not all the same, so.e are stiffer than others. Fox has one that you can adjust the charge pressure to change the feel.
sharpshooter
2004 - 2008 F150
Sep 21, 2012 12:24 AM
dustys7.3psd
Aug 3, 2009 03:33 PM
wfmcbride
Nov 14, 2007 01:43 PM
