Starter Relay
Old Sep 15, 2023 | 08:17 PM
Rollie 1's Avatar
Rollie 1
Starter Relay
I have a 1985 F250 and have been having trouble starting after setting for a few days. Some say the carb bowl is leaking. Since the fuel pump does not run unless the starter is cranking it has been suggested to jumper the battery to the "i" terminal on the relay for about 10 seconds to run the pump. My question is there are 2 small terminals on the relay and it is hard to tell where they go as some go in to a bundle. Can anyone tell me which is the "i" terminal - the right or the left?
Separate question: Why would Ford not design to run the pump when the ignition is turned on
Old Sep 15, 2023 | 08:38 PM
kr98664's Avatar
kr98664
Not sure about left or right, as a starter relay can be installed with either end up.
Look closely on the body of the relay. Should be a small S or I at the small terminals.
If not there, chock the wheels, put the transmission in neutral and momentarily connect a small test lead between the battery (+) post and either small terminal on the relay. The one that makes the starter spin is the S terminal.
BTW, your carb may not be leaking. Fuel may simply be evaporating after a few days.
Old Sep 15, 2023 | 10:31 PM
Rollie 1's Avatar
Rollie 1
Thank you. I looked but did not see any identification but will look again. You may be right on evaporation because I don't see any fuel leaking. Intend to take carb off and tighten all screws.
Old Sep 16, 2023 | 01:59 AM
kr98664's Avatar
kr98664
Separate question: Why would Ford not design to run the pump when the ignition is turned on?
Good question. Unfortunately, I’m unable to read the mind of anybody, let alone retired Ford engineers.
My best guess is they didn’t have to. They’d have been solving a problem that didn’t really exist at the time. Fuel chemistry has changed over the years and is no longer optimized for ancient carbureted vehicles.
Modern fuel no longer requires much resistance to evaporation, thanks to fuel injection and sealed tanks. But put modern fuel in a vehicle with a freely vented carburetor bowl and now evaporation can cause trouble.
In retrospect, we can say they should have included a pump prime function, but it wasn’t a needed feature back then.
Old Sep 16, 2023 | 07:42 AM
Franklin2's Avatar
Franklin2
Look at the color of the wires on the small terminals. The colors do fade, but the "S" terminal will have a red/blue stripe wire on it. The "I" terminal will sometimes be blue or pink/black.
Are you using the original carb but the emissions have been taken off? That aggravates this problem of evaporation.
Old Sep 16, 2023 | 08:20 AM
Max Capacity's Avatar
Max Capacity
I went out and checked my 86' 302EFI. The I is on the right, with nothing connected to it.
Old Sep 16, 2023 | 03:42 PM
Franklin2's Avatar
Franklin2
The colors on this wiring fade bad. You can faintly see the blue stripe on the red/blue wire in the picture above. Ford used the red/blue color for the start circuit for many years.
Old Sep 16, 2023 | 04:39 PM
kr98664's Avatar
kr98664
Another means to identify the small terminals:
Disconnect both wires. Use a multimeter to measure the resistance from each terminal to the relay base, where it bolts to the inner fender.
The S terminal is connected to the big electromagnet coil inside. The exact number isn’t important, but I’m guessing maybe 5-10 ohms.
The I terminal is isolated when the starter relay is not energized. You should see infinite resistance, same as if the meter leads aren’t touching anything.
Old Sep 17, 2023 | 05:03 PM
thomasphx's Avatar
thomasphx
4th Gear
Going to piggy back off of this thread... i inherited a 1985 F250 351 and I would like to know if the fuel pump is along the frame or in the tank?
Old Sep 17, 2023 | 05:37 PM
BigBlue2's Avatar
BigBlue2
You're better off starting a new thread. Title your thread appropriately and after you post you will likely see related threads below. Also Your thread may help others with similar issues.
kr98664
32
Aug 22, 2025 01:37 PM
SteevenH
1997 - 2003 F150
Dec 2, 2015 09:38 AM
stainlessstroker95
Dec 4, 2011 04:35 PM
Talyn
Jul 16, 2010 07:42 AM
The Grand Pooh-Bah
Electrical Systems/Wiring
Aug 13, 2003 06:26 PM
