stancor gpr work as starter relay?
Well my gpr finaly went out so i ordered the stancor relay. I would of just put another junk gpr109 if i never found this site thanks guys. So my relay works great and the darth vadar mask still fits on there. I was just wondering if the stancor relay could work as a starter relay on the passanger fender. Or if it is even nessasary. Thoughts?
^^^^ +1; run a short wire from the second small post to the the base to ground it, and Bob's your uncle. But it's overkill. The strength of the Stancor is its ability to hold the contacts in the closed position for long durations; that's how/when cheapo GP relays fail, powering the GPs for up to two minutes. But you're generally not running the starter relay for more than, Idunno, 8-10 seconds at a time.
