HORRIBLE Tires.
Old Jul 6, 2015 | 06:56 PM
tom18287's Avatar
tom18287
HORRIBLE Tires.
Just over 2 years and 23k miles, my f350 dump needs 6 tires already. The BFGoodrich tires that came on the truck are garbage. I'm very disappointed. I just replaced the front two for now because the I needed an alignment and it ruined the front tires, but the rear 4 aren't much better. Just waiting until winter to have fresh tread. anyone else have this issue?
Old Jul 7, 2015 | 06:26 AM
doublenot7's Avatar
doublenot7
Mine cane with Michelin on it, people complained of those also, but mine lasted past 60K.
Old Jul 7, 2015 | 07:38 AM
89LX306's Avatar
89LX306
Yep, my Michelins were throwing tread blocks at 14k miles. Pretty ridiculous if you ask me. I put Toyo MTs on and have 33k miles on them now with no tread blocks randomly ripping off and plenty of life left in them.
Old Jul 7, 2015 | 08:21 AM
Rod Bensken's Avatar
Rod Bensken
35K on my Michelins, so far so good. 99.99 highway (drove in my yard once or twice).
Old Jul 7, 2015 | 08:44 PM
dualwheels66's Avatar
dualwheels66
I don't like my BFG either, can't wait until they wear out, rears are doing good fronts are done., I probably will have to replace the fronts before the rears wear out.
Old Jul 7, 2015 | 08:52 PM
Pocket's Avatar
Pocket
Just food for thought, but an alignment issue will kill any tire.
Also have the tires been rotated? If not, that could be a problem as well.
Most OEM tires put on at production are different than what you purchase later as replacements. It's quite common for vehicle manufacturers to specify to the tire makers that tires put on during assembly be produced with lighter-weight materials. This typically softens the tires a bit, as well as quiets them down. It's to meet EPA standards, noise levels, etc.
So it's no surprise that if you buy the same tire as a replacement, it will last longer, reduce fuel economy, and be louder than the originals.
And at times there can be issues during a tire production run. Those Michelins that started falling apart after about 10K miles are an example. But that's not just limited to OEM production tires, it happens on retail replacement tires too.
Old Jul 8, 2015 | 01:19 AM
94ruck's Avatar
94ruck
13800 on my stock bfg. Look like brand new...
Old Jul 8, 2015 | 02:29 AM
Dakster's Avatar
Dakster
KR can come with Toyo's on them from the Factory...
Old Jul 8, 2015 | 05:48 AM
tom18287's Avatar
tom18287
i know that the alignment is was ruined the front tire. but the rears are all only have like 1/8" of tread left. another guy i know bought a truck with the same tires and his are almost gone as well.
Old Jul 8, 2015 | 08:29 AM
lwk362393's Avatar
lwk362393
Are the BFGs the Rugged Terrains? That's what my truck came with and they're doing really well. I'll likely put BFG A/Ts on when I need new ones.
Old Jul 8, 2015 | 07:10 PM
senix's Avatar
senix
Running the BFG rugged terrains on mine. 23K on them. While they are wearing well and have a lot of life on them I really don't care for them.
Old Jul 8, 2015 | 07:42 PM
Ferguson65's Avatar
Ferguson65
While I tend to agree with most of the post regarding my feelings on the factory BFG dually tires (not fond of them either), 23k seems a little low. My buddies 11 dually went close to 45k on the stock set. Mine has 12K on it and the fronts NEED rotated every 5k or they are going to have a very short life. My rears still look new. Are your rears worn even? Or is there something else going on? Or is the truck just loaded to the max (or over) all the time?
Old Jul 8, 2015 | 07:45 PM
DeeDubz's Avatar
DeeDubz
I recently replaced my Michelins with some nitto terra grappler mtz. Over all I'm pretty happy with them its an E rated tire. I got 55k out of my Michelins, can't complain about dat.
Old Jul 8, 2015 | 08:43 PM
bama29fan's Avatar
bama29fan
I got 45k miles out of the stock Michelin's. Probably could have stretched a few more out of them but the wear bars were getting close.
I just put bfg ta ko2's on yesterday. Only have about 60 miles on them so far so I can't say how well they will hold up but they have a real aggressive look for an all terrain. I really like them so far
Old Jul 10, 2015 | 05:28 AM
tom18287's Avatar
tom18287
i mean it's a dump truck. it weighs 11k empty. yes they wore evenly. for a dump truck, i think ours has a pretty easy life. it's been worked but not beat.
i know that i can have 3-4 ton in the back and tow my bobcat and the 6.7 doesn't even flinch
what an engine.
