1978 - 1996 Big Bronco
Need Help. EMERGENCY!!!
Old Nov 20, 2003 | 04:37 PM
bronco351's Avatar
bronco351
Exclamation Need Help. EMERGENCY!!!
Hi guys, I just bought a 1991 Bronco. It has the Electric Shift transfer case. As I type I;m in the process of removing the "thing" that engages the 4x4 that is directly connected to the transfer case.
The problem i'm having is there is about 4 wires and one brown one that come out of the transfer case and connect to the weather pack connector. How do you remove them. DO I have no choice but to cut them and then re-connect them.
I need to get to the parts store in an hour, before they close. Please help!!
Old Nov 20, 2003 | 05:26 PM
screwy's Avatar
screwy
do you mean the motor?
I just got done looking. ethier thier not the same t-case or im not understanding you right.
Old Nov 20, 2003 | 05:36 PM
dblue351's Avatar
dblue351
I think you are talking about the wires that go into a plastic thing on teh x case that is surounded by the case. You might not be becasue i think there are only 2 wires, but if that is it, yes you need to cut them and reattach them later.
Old Nov 20, 2003 | 07:11 PM
bronco351's Avatar
bronco351
Sorry about my confusing post. The part I was taking out is the Transfer-case motor. My Bronco has the Electric Shift Transfer case so, that motor engages the 4x4.
By the way I did cut the wires. I will just re-connect them when I put the X-case motor back.
The funny thing is this stupid transfercase motor is a Dealer Item only. I found this out when I rushed to the parts store.
I for sure won;t buy it from a dealer. It;s probable $200 there.
I will just go get one from a junk-yard tomarrow.
Thanks for the help guys.
Old Nov 23, 2003 | 02:09 AM
steve83's Avatar
steve83
Read this article.
2broncs
Aug 30, 2019 09:24 PM
jtapal
18
Dec 23, 2016 05:15 PM
Enduroman
Dec 6, 2013 02:53 PM
runner
Dec 27, 2003 04:36 PM
Lobuck76
Aug 29, 2003 10:35 PM
