I need some of yall's vast knowledge.
I'm looking for a transfer case for my 94 bronco, 351w,e4od.
Iv'e located one out of a 93 ford 1/2 ton pick-up that is priced right.
The folks at the salvage say bronco shows to have a different transfer case than the pick-up of same years.
What might the difference be? A Major issue, or something I can work around?
Any help would be helpful. Thanks,ron
Thanks for the replies.
I just bought the Bronco. for reasons unknown the previous owner installed an electric shift tc, the vehicle is set up for manual
shift tc. linkage/shift motor not hooked up.
I'm thinking the right way to go is to replace tc with correct (manual shift) transfer case.
