Shifter Arm help / part #
Old Sep 5, 2023 | 10:13 PM
flhx06's Avatar
flhx06
I have a ‘57 F100 with a 223 and a 3 on the tree. The previous owner cut the shifter arm to install a custom shifter. My question: isn’t the shifter arm replaceable? And if so, does anyone know the part number or where I can get one?
Thanks in advance!!
Andrew
Old Sep 6, 2023 | 05:10 PM
spurredon's Avatar
spurredon
Which end of the column are you talking about?
Old Sep 6, 2023 | 05:15 PM
flhx06's Avatar
flhx06
Closest to the steering wheel. I guess the shift lever would be the proper terminology. In simplest terms...the piece you grab to shift it into gear
Old Sep 7, 2023 | 05:36 PM
spurredon's Avatar
spurredon
There are quite a few guys here that have done the whole Crown Vic conversion and are using the column that came with it. There must be some laying around. I can't believe they are got scrapped already.
Old Sep 7, 2023 | 06:14 PM
spurredon's Avatar
spurredon
Mine is a '60 and the shifting lever is held in by a roll pin not sure if that is how it is for a '57.
Old Sep 8, 2023 | 08:37 AM
flhx06's Avatar
flhx06
I believe they can all be replaced. I’m just trying to figure out where to get one. Hoping I can get lucky with someone knowing a part number and/or a place that has one. I would even take an entire column like you suggested.
Old Sep 8, 2023 | 05:58 PM
spurredon's Avatar
spurredon
Not cheap by any means but https://www.ebay.com/itm/19572541625...2B3XFzf7n0IUj2
Arozier77
May 5, 2023 02:15 PM
ADOR
Oct 30, 2013 07:02 PM
Rob Cuenin
Jul 13, 2013 03:54 PM
F3Beam
Jul 29, 2009 09:13 PM
Cracker289
Aug 31, 2004 01:15 AM
