Column shifter arm quit
Old Jul 27, 2009 | 06:18 PM
F3Beam's Avatar
F3Beam
Hi,
Today while driving in town the Column shifter arm quit shifting the linkage on my '83 F100, 3 on the tree, 300 6cyl. At first I thought my linkage must have slipped off somewhere, but soon saw the problem was that the shifter arm must have broken/slipped something off inside the column. I drove the 35mi. home in 2nd gear. Shifter arm lost contact with whatever it connects to inside the column.
Any idea what went wrong inside the column, and what it will take to fix?
Thanks.
Old Jul 28, 2009 | 10:46 AM
F3Beam's Avatar
F3Beam
Been calling local shops and this looks like a major procedure to repair. Seems the only reasonable fix is either find another whole column and replace or install floor shifter.
Old Jul 28, 2009 | 01:23 PM
4caster's Avatar
4caster
I worked for a company in 1986 that had a similar problem with a 72 Dodge PU. The cheap and easy solution was to install a floor shifter. The other option would have been to find a donor column with three on the tree.
Old Jul 29, 2009 | 08:55 AM
F3Beam's Avatar
F3Beam
Yeah, cheap and easy is the girl for me.
Called Autozone about the Mr. Gasket #7667 3-Speed shifter: $139.99
Then called O'Reilly about same shifter but #7667A: $65.xx
Not sure what the A means in #7667A, but that $65 is the one I bought. Other threads seem to show #7667 works okay.
Old Jul 29, 2009 | 10:51 AM
bghnkinf250's Avatar
bghnkinf250
I was working on one of those where it would lose contact intermittently. It turned out to be the shift collar on the column that the shift arm sat it. It was worn out and giving a lot of play. I believe LMC or NPD sells them for about $75 give or take.
Old Jul 29, 2009 | 09:13 PM
F3Beam's Avatar
F3Beam
I think that is probably the problem with mine, I can slide the collar around and there is nothing it is attached to inside. I would have liked to fix the 3 on the tree...but after buying the 3 speed floor shifter, I'm looking forward to the crossover and trying a floor shift. All these old trucks seem to be picky about going from 1st to 2nd...maybe floor shifter will strike it with ease.
ratrod1923
21
Oct 4, 2019 02:07 PM
jdsdidit
22
Apr 2, 2008 07:57 PM
ron65
Jan 6, 2007 04:06 PM
RidinNStyle54
Jan 10, 2006 05:30 AM
Cracker289
Aug 31, 2004 01:15 AM
