Sponsored by: Real Truck
E40D Transmission Diagnosis Help Requested
Old Sep 2, 2023 | 11:01 PM
wannabuyaford's Avatar
wannabuyaford
Oops, posted in wrong forum.
Old Sep 3, 2023 | 11:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a good chance that the PSOM (Programmable Speedo/Odo Module) is your problem. It is mounted to the back of the instrument cluster. You might want to open it up and see if there is any visible damage. The capacitors can leak and cause problems.
Old Sep 3, 2023 | 04:54 PM
wannabuyaford
Would the PSOM only cause speedometer problems, or also cause problems shifting? Because the speedo only got wild after I changed the VSS so I'm *guessing* it's related to that somehow?
Old Sep 3, 2023 | 10:09 PM
Mark Kovalsky
The PCM uses vehicle speed info from the PSOM to schedule the shifts. If the signal is bad the shifts will be at the wrong time.
wannabuyaford
23
Oct 14, 2023 10:28 AM
lciambotti
Nov 5, 2008 05:49 PM
TPM
Apr 12, 2007 08:21 PM
djtech
Jul 20, 2006 08:32 PM
F2_350
Jan 25, 2002 06:58 PM
