E4OD problems
Old Jan 22, 2002 | 02:36 AM
F2_350's Avatar
F2_350
E4OD problems
My '92 F250 is having major shifting problems. It won't shift out of low unless manually shifted, and occasionally slips out of 3rd while driving, cold or warm. Speedometer is also inop, except for an occasional deflection now and then. There are no problem codes in the computer. Anyone have any ideas??? I'm really stumped on this one. The truck only has 85K on it, and trans has been serviced every two years, filter and fluid. I'm no mechanical idiot, but not a tranny expert either. Any ideas or opinions would be greatly apprecitated.
Doug
Old Jan 22, 2002 | 07:10 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
E4OD problems
The transmission uses the signal from the speedometer to shift. If the speedometer doesn't work, the transmission won't shift correctly, or may not shift at all.
The speedometer uses the sensor on top of the rear differential. A new sensor from the dealer should be less than $15. It takes one bolt to change it. That's what I'd try first.
Mark
Old Jan 23, 2002 | 12:07 AM
Ratsmoker's Avatar
Ratsmoker
E4OD problems
The sensor on top of the rear differential is not the sensor for the speedometer. It is the sensor for the ABS system. The Variable Speed Sensor or VSS is located on the drivers side of the tranny and can cause shifting problems as well as speedometer problems. It is a fairly inexpensive component and is about a 5 minute job to change.
Old Jan 23, 2002 | 07:32 AM
Mark Kovalsky
E4OD problems
When I had a '94 there was only one sensor, the one on top of the diff. When it failed the speedo stayed at 0 and the transmission didn't shift correctly.
Mark
Old Jan 23, 2002 | 11:15 AM
StrangeRanger's Avatar
StrangeRanger
E4OD problems
In the 96 the VSS is the same sensor as the RABS. I'm pretty sure the 92 is the same, it uses the same instrument cluster and logic pkg.
Old Jan 23, 2002 | 11:19 AM
Ratsmoker's Avatar
Ratsmoker
E4OD problems
>Mark
Well that must be on the 92 - 96 series then. Could be right. On my 91 F-150 my VSS sensor went out and caused tranny problems and on my dad's 1988 he knocked the sensor on his rear diff off and it caused his ABS not to work.
Old Jan 23, 2002 | 12:33 PM
F2_350's Avatar
F2_350
E4OD problems
In my research and talking to local tranny shops I have run into this debate on several occasions. While there is a sensor on the rear differential, the only wiring from the trans itself connects on the drivers side of the tranny just above the shifter linkage attach point with several wires on a flat connector. I would assume these are for the reverse lights and signals to solenoid pack inside that operates the valves in the valve body, and maybe neutral safety. This truck also has abs problems, so I'm going to change the sensor at the rear end first. I will let you all know what happens. Thanks to you all for your input.
Doug
Old Jan 25, 2002 | 05:29 PM
F2_350's Avatar
F2_350
E4OD problems
Ok, the truck is fixed. I replaced the sensor on the diff housing, and that's it. The abs and speedo working proplerly, trans shifting normally. Cost me less than $15. Had to go to the dealer to get it today, and the funny thing is even they don't know what all that thing effects. The guy at the counter said all it controls is the abs. I guess nobody knows everything.
Just a little return to you guys for the time you invested replying to my call for help. Thanks again. I hope this posting will help someone else with similar problems.
Doug
Old Jan 25, 2002 | 06:13 PM
Ratsmoker's Avatar
Ratsmoker
E4OD problems
Thanks for filling us in. I though for sure that that the diff sensor was for abs only but my dad's truck was a manual so of course that was all it was for. Glad you got it fix so cheaply.
Old Jan 25, 2002 | 06:58 PM
pYro's Avatar
pYro
E4OD problems
Doug913
6.7L Power Stroke Diesel
Feb 14, 2011 09:17 AM
doug70
Sep 16, 2010 12:03 PM
Doug The Dog
Apr 9, 2008 01:46 PM
OLD DAWG
Nov 27, 2004 07:03 PM
fiddy
Dec 11, 2001 08:40 PM
