Sudden Speedo Malfunction
Old Nov 4, 2008 | 09:02 AM
lciambotti's Avatar
lciambotti
Trailering
1996 460CU, E040D Tranny. Speedo was working fine. Pulled in to get gas. Pulled out, speedo bounced a few times and quit all together. Of course this made the tranny go haywire. Any idea where to start?
Thanks
Old Nov 4, 2008 | 09:18 AM
Lou Braun's Avatar
Lou Braun
There is a speed sensor connected to the top of your rear differential. It is held in place by one bolt.
Check the connection at the sensor or replace the sensor if necessary. The only potential problem with this repair happens if you snap the bolt that holds the sensor in place. Penetrating fluid prevents this problem.
Lou Braun
Old Nov 4, 2008 | 09:52 AM
lciambotti's Avatar
lciambotti
Trailering
I'll change it out and report back.
Thanks!
Old Nov 4, 2008 | 03:07 PM
T.L. Timmons's Avatar
T.L. Timmons
sounds like what my 95 F-150 4x4 5.8 is doing but mine has contiued to keep working at times
Old Nov 4, 2008 | 03:08 PM
T.L. Timmons
I have already changed that sensor and it has continued to react the same as before
Old Nov 4, 2008 | 03:19 PM
danr1's Avatar
danr1
First thing you need to do is check for codes, don't replace any parts and don't disconnect the battery until you've done so.
Old Nov 5, 2008 | 04:33 PM
lciambotti's Avatar
lciambotti
Trailering
I forgot to mention that my O/D light is flashing.
Thanks
Leon
Old Nov 5, 2008 | 05:49 PM
droppedf100's Avatar
droppedf100
I had this happen on my 96 F150 5.0 E4od and it ended up being the sensor in the actual speedometer itself. I changed the sensor on the rear and it didn't help at all. Then I changed the speedometer in the cluster and I haven't had a problem since 15,000miles later.
Squarebody
Oct 22, 2013 12:16 AM
tip49
Jun 20, 2013 10:38 PM
ken selvy
Aug 30, 2006 03:07 PM
chickenmanq
May 17, 2002 07:58 PM
