First check engine light.
Old Aug 31, 2023 | 05:35 AM
jets20's Avatar
jets20
Just got my first check engine light on my 2019 Lariat 6.7 with 55k miles on it. It had a very brief stumble when starting a couple days ago almost like the batteries were weak. Got this message on the App when I started it to go home from work that same day. I put a new air filter in. Old one was dirty but certainly not restricted. Will I need to use Forscan to reset the light and what else might have caused this warning? Truck is running fine and fuel filters were changed during last oil change also.
Old Aug 31, 2023 | 08:52 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That message doesn't tell us anything, we need to know the code.
Forscan is not needed to clear the code, just a good scan tool, but you don't want to clear it before letting us know what it is.
Old Aug 31, 2023 | 08:27 PM
jets20's Avatar
jets20
P0170, fuel trim (bank 1). I watched a good troubleshooting video where it was traced to a MAS with high kHz readings at high rpm. He also spoke about checking the cold side charge pipe. We’ll, mine had a one inch tear in it and the clamp was loose on the engine side. Got it taped up for now until the new one arrives and I cleaned my mass airflow sensor. Just have to get the light reset to see if it stays cleared.
Old Sep 1, 2023 | 08:21 AM
jets20's Avatar
jets20
Check engine light went out on its own on a drive this morning so I suggest anyone getting this code check the MAS and turbo inlet pipe. From what I’m seeing now, the pipes have a high fault rate.
Old Sep 1, 2023 | 10:27 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, up through 2019, all piping changed in 2020 with the updated engine.
Old Sep 1, 2023 | 10:55 AM
4wd6.7L's Avatar
4wd6.7L
17-22 use the same CAC pipe. They are supposed to be of a better design than the pipe used on earlier years (11-16), but they still fail.
Old Sep 1, 2023 | 12:00 PM
WXboy's Avatar
WXboy
Is the one that fails an easy one to replace? Or do you have to tear half the engine apart to reach it?
Old Sep 1, 2023 | 12:09 PM
4wd6.7L's Avatar
4wd6.7L
It's an easy one. About a 10 minute job.
fabian.219
Aug 31, 2023 09:11 AM
Gwilkrrs
Jan 21, 2022 08:26 AM
Big Silver One
May 31, 2019 09:18 PM
Raymundo g
6.4L Power Stroke Diesel
Jun 23, 2015 10:58 AM
powerstroker04
Dec 3, 2007 07:18 PM
