2017 with 104k, on the way into work i noticed the check engine light came on. freaked out a bit, have to wait all day to get back and try to scan it......... o the possibilities......
The ability to read engine codes, without a scan tool, on my last Ram was a plus...too bad that I had to use it so frequently at times. Cycle the key 3 times w/o starting the truck, leaving it turned to on at cycle #3 and read the codes as they appeared across the odometer. Write them down and Google away. Though towards the end I just carried the scan tool with me at all times so I could reset them if they affected operation.
so last night after a 1 hour drive home i read the codes.
p220E
nox sensor heater
control circuit
range/performance
bank1 sensor1
p2200
nox sensor circiut
bank1 sensor1
i cleared the codes and drove 15 minutes with no cel. this morning i drove 20 minutes and the cel came back on. got to work and pulled the codes to find the same 2
Yes there is. It's called the "blindly replace parts in the hope that you might stumble onto the issue before your savings are depleted" method. You would be surprised how often this method of vehicle repair is used.
well there is that. Ive been guilty of that on stuff….
