Ford auto hubs
Old Aug 28, 2023 | 06:50 PM
  #31
Jmcx1969's Avatar
Jmcx1969
I bought a hub off Rockauto. It turned out to be a lock/free version. Not auto/lock. RA doesn't even offer a A/L version that l could find. Then l tried Amazon. It was the correct style but poorly manufactured and the diaphragm clamp just fell off. Ford it was.
The bigger problem is that inner seal failing and no vacuum develops to actuate the hub.
Old Aug 29, 2023 | 06:53 AM
  #32
senix's Avatar
senix
Originally Posted by jimzpsd
They're not wearing out, they will seize up at the actuator ****, auto select still works to engage 4wd, but if you want to manually lock them they become hard if not impossible to rotate from road salt, dirt, etc.
That is why you rotate the **** monthly and run them for about 10 miles.
You can also take them apart and service them at about 50-60K miles if needed.
Old Aug 29, 2023 | 07:13 AM
  #33
jimzpsd's Avatar
jimzpsd
Have you read this entire thread? I mentioned how often I use them weekly (manually) and I also posted a video of how to disassemble them .......and I also posted the the **** actuator itself is the culprit that seizes up and is non serviceable.
Old Aug 29, 2023 | 07:24 AM
  #34
senix's Avatar
senix
Yeah, my bad, did not read down far enough to see that you already addressed this issue.
Are the hubs getting submersed in mud that it gets in there?
Old Aug 29, 2023 | 08:51 AM
  #35
DSLTRK60's Avatar
DSLTRK60
It was HeavyAssault and DLSTRK60 that originally posted back in March telling me the OEM hubs are made by Warn...............darn internet lol
Is this disputed? Warn does make the factory Ford hubs. The sintered clutch gears are identical between the Warn Premium and Ford OEM. There's also a Warn factory video showing them building the OEM Ford hubs in the background.
At $500 now, perhaps the real reason why Warn doesn't offer a vacuum actuated "Premium" hub is cost and market acceptance.
Old Aug 29, 2023 | 10:12 AM
  #36
JayCarver's Avatar
JayCarver
Is there anything to service in these? Or are they pretty much sealed up.
Old Aug 29, 2023 | 12:40 PM
  #37
jimzpsd's Avatar
jimzpsd
In my opinion, the source for the debris is entering through the letters that say FORD in the center of the ****. Years ago I was washing my truck with soapy water, and as I was washing the hub and center cap, I turned the dial to lock and I saw bubbles coming from the open FORD letters. Posted years ago about this and someone said its from the vacuum diaphragm blowing out through the letters so it can release the vacuum. I'll search for this post and post it if I find it.
Old Aug 29, 2023 | 12:57 PM
  #38
jimzpsd's Avatar
jimzpsd
I found it:
#16 Report Post
Old 03-24-2018, 11:48 AM
@dnewton3
dnewton3 is offline
Just so folks understand how this is supposed to work, I'll give an overview of the system ...
To start with, let's first talk about a traditional brake system. The master cylinder holds the fluid. As the fluid is "replaced" into the pressure side via the return of the rod along it's return stroke, the fluid volume has to be supplied by the reservoir. If that reservoir were completely sealed, it too would have a vacuum which would deter the free and timely flow of fluid into the sealed portion of the system. Hence, there's a tiny hole to vent one side; typically on the cap and goes through a baffled rubber piece.
The 4x4 vacuum system is similar (not same, but close). The vacuum side is on the inboard side of the hub. There is a piston-type movement that the hub uses to "pull" to engage the hub drive when the vacuum is applied. If there were no relief on the other side, then once side of vacuum would actually create vacuum on the opposite side and the movement would stall. In essence the two vacuums would try to balance out and the locking mechanism would not get fully engaged or disengaged. For it to work right, when the vacuum is applied, the other side MUST have the ability to draw atmospheric make-up air volume from somewhere which is NOT restricted. So there's a tiny vent-like design applied to the outboard side.
When the OP washed his truck, it was no big deal. But when he applied and released the 4x4 by activating the vacuum system, it will draw in a tiny bit of outside air as the hub locks, and then expel it again as the system unlocks. The water present with the air will also go in and out. It's unavoidable and expected. But it's also why the systems will eventually get dirt and corrosion inside, and then be slow to engage, or get stuck one way or another, or worse yet, stuck mid-stroke.
There are springs inside the mechamism. Typically these are not needed for the application of 4x4; the vacuum does this. The springs are to encourage the return of the hub lock AFTER the vacuum is ceased (4x4 turned off so the vacuum signal is stopped on inboard side). Then the spring returns the slider to the unlocked position. If done manually, there's a cam that engages with the tuning of the dial that overcomes the springs, and then when the dial is returned to the "unlock" position, the spring resets the system outward again. So either way, the mechanism has to be moved inboard to lock (vacuum or dial cam) and then the spring returns the system to open when vacuum ceases or manual over-ride is dialed "open".
So as to be clear, the vacuum side of the system needs to be fully sealed. However the slave-side of the system has to be open to available pressure to offset that, so the mechanism will activate. If there were vacuum present on the other side, it would not work properly. (Note - vacuum could be used for both sides, but that would complicate the system and both would still need a volume chamber to draw from opposite of the vacuum application).
I recommend taking the system apart once a year, cleaning the guts and applying a VERY light lube (like sewing machine oil or a mist of 3-in-1; not heavy grease or thick oil). If one cannot reasonably turn the locking hub by hand, it's dirty enough to need service.
Old Dec 3, 2024 | 09:54 AM
  #39
Richard Aarts's Avatar
Richard Aarts
Do the warn hubs automatically lock when shifted into 4 wheel drive or do you have to manually lock the hubs before hand?
Old Dec 3, 2024 | 11:30 AM
  #40
jimzpsd's Avatar
jimzpsd
Old Dec 3, 2024 | 11:32 AM
  #41
Richard Aarts
Can I leave them locked when driving on dry pavement in 2 wheel drive?
Old Dec 3, 2024 | 01:53 PM
  #42
jimzpsd's Avatar
jimzpsd
Yes. Mine are currently locked right now for the rest of the winter, simply shift into four wheel drive as you need and back to two wheel drive. You can even shift while moving, but for four low you'll need to stop the vehicle and shift the transmission into neutral first. Most manual hub kits will come with a vacuum hose cap(s) for each side. Vacuum engagement is no longer used with this set up. Manual hubs have been around for decades, nothing new here.
Old Dec 4, 2024 | 05:13 AM
  #43
Gwilkrrs's Avatar
Gwilkrrs
well my hubs are shot-
i took them out and the plastic retainers are broken holding the gears. i can manually turn the **** (stiff) to look them in but auto is no more. i did not service the hubs (150k) and the **** was so tight i needed to put an adjustable on it to turn it (was stuck) so i likely forced broke mine instead of servicing.
i bought a set off amazon for $150 aftermarket. they would not install. they wouldnt spline in , i returned them and bought from another vender and they wouldnt spline in either. so i will just save up for the factory set.
Old Dec 4, 2024 | 08:39 AM
  #44
jimzpsd's Avatar
jimzpsd
Its why I went with manual hubs (WARN) wasn't going to mess with it ever again. IMO, the factory design is nice but the build suffers.
sailorman3
Jun 3, 2015 12:23 PM
hdman6
Sep 10, 2014 03:18 PM
BDawg171
Jan 13, 2010 02:29 PM
jimmeyjack
Oct 23, 2005 11:34 PM
