Sponsored by: Real Truck
Help! Need pump, unrelated codes
Old Aug 24, 2023 | 06:28 PM
dakota333's Avatar
dakota333
I have a 2013 I just put a new DCR pump in. No issues before the install other than taking a couple seconds longer to start than an average 6.7. After the pump install I got 3 codes. P2122, P06A6, P0532. Takes a lot longer to start now and has a tick/miss. Also has a wrench light. I just recently got a crank position sensor code a couple days later. P0335 I believe, I can double check that later. I have already tried new batteries. Any help would be much appreciated.
Old Aug 27, 2023 | 12:18 PM
redford's Avatar
redford
FTE Leadership Emeritus
I'd focus on the P06A6 code first. If your reference voltage is off, everything else may or may not be a valid code.
Old Aug 27, 2023 | 03:10 PM
Matthew_in_CO's Avatar
Matthew_in_CO
I'm here to learn what I can, very novice on the 6.7. Not sure if you have access to forscan but watching individual sensors and checking their signal voltage might point you in the right direction. Good luck!
Old Aug 27, 2023 | 03:23 PM
dakota333's Avatar
dakota333
Redford- unfortunately from what I’ve been reading with my symptoms, I’m leaning towards pcm. From what I’ve seen, all of my wires appear to be good. I think my rail pressure sensor shorted and fried that part of the pcm. How can I test my pcm? Thank you
Old Aug 27, 2023 | 03:25 PM
dakota333's Avatar
dakota333
Matthew- yes that would be a good idea. I’ve heard of forscan, looking into that. Honestly if it cost as much as a pcm I might just buy a pcm and chance it. Hopefully I can get some more input before I pull the trigger.
Old Aug 27, 2023 | 03:26 PM
dakota333's Avatar
dakota333
Also getting readings on my phone thru the ezlynk app, my rail pressure stays at 3.6 Kpa running or not
Old Aug 27, 2023 | 04:25 PM
Matthew_in_CO
It's free, might require you to buy an adapter, depending on your computer
skipalongrice
1978 - 1996 Big Bronco
Nov 18, 2015 10:04 AM
bcaughhorn
1997 - 2003 F150
Jan 24, 2013 07:48 PM
shawbran
Sep 6, 2011 06:41 AM
Mike Norwood
Mar 23, 2009 09:19 PM
Saurian
Sep 8, 2004 10:26 PM
