I just checked my computer I have a couple codes
P0453 evap emission system pressure sensor/ switch high
P0232 fuel pump secondary circuit high
C1303 right front isolation clamping circuit..
P0305 cylinder 5 misfire.
I changed the fuel pump 2 days ago and the coil on cyl 5.
Can somebody point me in the right direction
If you just changed the fuel pump, the two codes 232 and 453 are related to the pump work. Likely the plugup connector has some opens for those circuits.
The 305 is seperate. Did you use grease on the boot so it 'find' the plug tip and not get hung up? If you don't feel the missfire the code is old history.
The C code you just have to chase down.
Good luck.
