Fuel Injector code
Old Aug 23, 2023 | 10:37 PM
Scott Deal's Avatar
Scott Deal
6th Gear
Fuel Injector code
Hey All,
2018 3.5 Ecoboost
While driving at highway speed either with cruise control activated or maintaining an even speed with the pedal I have experienced a moderate frequency shudder. To stop it I either stabbed the throttle or tapped the brake. The third time this happened the check engine light came on. Put the ODBII on it and got p21D2. I have a new FORscan adapter headed to me for more info on the code. Does anyone else have any insight to my situation. Thank you for any help or advice on this one.
Old Aug 24, 2023 | 06:42 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Denny
Old Aug 24, 2023 | 06:45 AM
projectSHO89's Avatar
projectSHO89
Here's the definition for the P21Dx DTC, cylinder #4 in this example.
P21D2 - Cylinder 4 Injector B Circuit/Open
Description: The comprehensive component monitor (CCM) monitors the operation of the fuel injector drivers in the PCM. This DTC sets when the fuel injector circuitry is inoperative. Possible Causes:
  • VPWR circuit open
  • INJ4 circuit open
  • Damaged fuel injector 4
  • Damaged PCM
Diagnostic Aids: The INJ4_F PID flags equals YES. Application
Key On Engine Off Key On Engine Running Continuous Memory All
GO to Pinpoint Test KG .
Since the fault appears to be intermittent, I'd put the injector and/or its pigtail at the top of the suspect list.
Old Aug 24, 2023 | 08:05 PM
Scott Deal's Avatar
Scott Deal
6th Gear
Thanks both of you for the guidance. Not really jazzed about pulling the intake off to get to that injector but shouldn’t be too bad. My wife and I recently moved to a very rural setting so hopefully I don’t find any rodent activity.
I plan on replacing the injector in question for sure unless there is clear evidence of a different culprit. Do you think it would be wise to replace all the injectors while I have things apart?
Old Aug 29, 2023 | 04:58 PM
npccpartsman's Avatar
npccpartsman
Depending on your mileage it may still be under emissions warranty?
StrummerK
Apr 29, 2021 10:37 PM
wbates82901
Dec 2, 2017 04:22 PM
kirbylp
6.7L Power Stroke Diesel
Mar 26, 2016 07:18 AM
CR125Honda
Jan 26, 2007 11:01 PM
93DieselGuy
Feb 7, 2005 09:53 PM
