07' PCM Pinout Chart
I recently bought a 2007 FX04 5.4l 4R75E that had multiple issues. I done a thorough timing job as well as a valve body conditioning. I now have only two codes left to clear, that is P0717 and P0715, both are TSS codes. I conducted a pinpoint test and found all resistances within range, 570 ohms for the sensor. I have a doubt that the transmission harness might have been replaced with that of another year model because of the evidence of cutting the harness at the component sides. Since everything else is working fine, I just want to confirm that the signal wire coming from the TSS sensor is connected to the correct pin. I found pinout charts of other models from 2004 to 2007, but each one is unique as per its part number. However, I haven't found any with My PCM's part number, 7L3A-12A650-GAD with an identifier AFV3.
Where can I find these charts? Anyone, HELP!.
