Oddball propane fitting - advice?
Old Aug 21, 2023 | 10:02 AM
seventyseven250's Avatar
seventyseven250
So it turns out the trailer I bought this year has a fitting that isn't very common. The hose that goes between the regulator (at the tanks) and the hard-pipe under the trailer has a 1/2" SAE male flare fitting, not the much more common 3.8" SAE flare. I can't for the life of me find a propane hose with 1/2" Female flare, OR, a fitting that will convert 1/2" flare to 3/8" flare in that location. The trailer is a 2007, and the hard pipe and fittings on the hard pipe are pretty "locked up". The normal way to fix with would be to take the fitting off the end of the hard pipe, and just install an NPT pipe fitting with a normal 3/8" flare fitting. I'm very concerned I'm going to break something in that hard pipe system, and then I'm replacing a bunch of the hard pipe under the trailer too. I'd like to avoid that.
So to summarize I have: 1/2" Male SAE Flare and need to get that to the regulator (with a 48" hose" in there). Existing hose is too short to route around my battery box.
Looking for ideas.
Old Aug 21, 2023 | 06:13 PM
john jamieson's Avatar
john jamieson
Maybe a shop that makes hydraulic and ac hose/lines could fabricate what you need.
Old Aug 22, 2023 | 01:39 AM
EDC8008's Avatar
EDC8008
Check McMaster Carr, they have quite the selection of different adapters for different types of fittings.
Tact
Jan 10, 2014 02:07 PM
RÖENTGEEP
Sep 30, 2008 03:24 PM
seawulff
Jun 30, 2006 10:19 AM
93Ranger183K
Dec 6, 2003 07:41 PM
dsmtech
Jun 11, 2003 07:25 PM
