56 Coss-over Pipe
Old Jun 29, 2006 | 07:30 PM
seawulff's Avatar
seawulff
56 Coss-over Pipe
I have a 1957 312 in my 1956 F100 and am converting from dual exhausts to single with a cross-over pipe. The hose which goes from the water pump to the heater has no clearance under the cross-over pipe which rest right on it. I don't think that I can redirect the hose because the nipple that it connects too is fixed. Is there a concern having the hose in contact with the cross-over pipe or can the hose tolerate the heat that it will be exposed too. Thanks.
Old Jun 29, 2006 | 09:07 PM
56f600's Avatar
56f600
The heater hose will not take the heat from the crossover pipe. I believe you need to change the nipple and put in a street ell. A 90 that is female pipe thread on one end and male pipe thread on the other. If I remember correctly(which is a rarity anymore) that is what I did with my '56.
Old Jun 30, 2006 | 10:19 AM
seawulff's Avatar
seawulff
The pipe that comes out of the water pump is a 90 degree bend already to I attack something on to this or take this out of the water pump and put a different one on. I don't think I understand the difference.
