Blue Wire Mod --Again--
Old Aug 14, 2023 | 05:41 PM
Excurvelle's Avatar
Excurvelle
A/C was struggling at 97 degrees yesterday in the city, thinking about the Blue Wire Mod. I have been reading about it more and more. Besides mounting the switch without damaging my dash what are the other pros and cons. I am not a fan of damaging factory wiring harnesses so I will use a tap with a spade connector. Does it cause any issues with the truck?
Old Aug 14, 2023 | 06:47 PM
kbeefy's Avatar
kbeefy
Do you know if your fan is functioning properly to begin with?
I'd prefer a splice and a spade over a tap.
Old Aug 14, 2023 | 07:11 PM
bismic's Avatar
bismic
It won't cause any issues with the truck.
Old Aug 14, 2023 | 07:47 PM
Excurvelle's Avatar
Excurvelle
Yes, it comes on and works normally, A/C just can't get cold in heavy traffic, does fine on the highway.
Old Aug 14, 2023 | 07:48 PM
Excurvelle's Avatar
Excurvelle
Thank you! Some time has passed from a lot of the posts and wanted to make sure nothing has popped up.
Old Aug 15, 2023 | 05:58 AM
jsm180's Avatar
jsm180
I just replaced the the fan clutch on mine, fan wouldn't come on with ac on max. Ac was weak in stop and go traffic. Checked the fan speed, it stayed constant at 650 rpms. New fan clutch, now fan speed goes to max on max ac and holds 8-900 rpm at idle. Ac back working normal. Still putting off doing the blue wire mod.
Old Aug 15, 2023 | 07:03 AM
Excurvelle's Avatar
Excurvelle
When towing my fan ramps up at 207, I am running the 200 degree thermostat, engine temps normally stay between 200 and 204. I have replaced the fan clutch and watch the FSS PIDS seems to operate normally. I also replaced the pressure switch behind the compressor.
I am wondering if the condenser is restricted, the pressures don't show that or with the high humidity and hot car the system cannot keep up. Seems to cool nicely under 95 degrees.
Old Aug 15, 2023 | 07:43 AM
bismic's Avatar
bismic
That is why I do not switch to a 200*F thermostat. Some people claim more efficient running, but if it is, it is not even measurable.
Old Aug 15, 2023 | 07:47 AM
TooManyToys.'s Avatar
TooManyToys.
I’ve washed my condenser (and radiator) several times, when I've had the cooling stack both in and out of the vehicle. I’m always amazed how much dirt collects on them.
You can get coil cleaner at HD/Lowes and other places that is used on home A/C condenser coils. Its foaming and doesn't take long. For rinsing, you don't want a pressure stream, you want a shower spray.
Old Aug 15, 2023 | 09:31 AM
jav_eee's Avatar
jav_eee
shoot mine hovers at like 400 rpm at idle. I bet my clutch is toast.
Old Aug 15, 2023 | 09:50 AM
kbeefy's Avatar
kbeefy
Have you had the Refrigerant level checked?
Old Aug 16, 2023 | 05:06 PM
Excurvelle's Avatar
Excurvelle
Been thinking abut switching out, Is there a decent OEM type that fails open and actually works?
Old Aug 16, 2023 | 05:31 PM
bismic's Avatar
bismic
I have just stuck with the Ford or International part. I have little respect for Mishimoto stuff.
Old Aug 17, 2023 | 08:45 AM
HydroTek's Avatar
HydroTek
Be sure that the air blend door is working -- also check that the water valve is closing off with the AC on max
Wash out the air stack as was mentioned , and check for bent fins -- air gotta get thru there
Does the fan RPM increase when the AC is turned on ?
Old Aug 17, 2023 | 01:43 PM
Excurvelle's Avatar
Excurvelle
I am going to clean the fins this weekend, I have a can of coil cleaner. Recirc helps the a/c.
The fan does increase in speed some but not like a traditional clutch fan, the PCM has to command it. Funny, it only really acts up at 96 degrees and higher, today it is 87 and it will cool just fine. It has also been very humid and add that to 96+ degrees and sitting in the sun it takes a while for the colder air to flow.
