Blue Wire Mod --Again--
Really don't like vehicle information in the siggy -- rather have it in the opening post , for clarity
We have a camping trip this weekend, I don't want it to be out of service this week.
this will at least turn off the hot coolant from the heater -- in case your air door seals are damaged or not fully operating
Pulling the blower motor and taking a look see , would be good -- may be part of a critter nest in there
The 2 lines on the accumulator are the same size on my truck -- they represent inlet and outlet for the accumulator / drier -- both should be the same temperature
The smaller line near the accumulator is the high pressure line , and the junction near the heater box is where the orifice tube sits
the line preceding the junction would be warm-ish , but just after would be the start of the temperature change
Feeling of the 2 lines where they run from the cooling air stack , would be the one is from the compressor (hot) and the other is after the condenser (ambient plus)
A lot can be learned about the health of an AC system by checking the temperatures (feeling) of the lines
if the line from the condenser is still too warn , then the air flow over the condenser is suspect
Right before we headed on a trip to Yellowstone it was hot in the East and the a/c actually popped off refrigerant. My shop immediately took it in, ready to do whatever so it was ready to go. Said everything was fine just at idle it was not as cold. The popping off to me was either over charge or lack of air flow.
We took our trip, KY was hot, the A/C struggled and fortunately the West was cold (even snowed on us). I have gotten to the point of wanting a second opinion on the system. My dealer is a small country shop and they are going to look at it on Tuesday.
Thanks for all of the advice. I am holding off in the Blue wire mod, TBH I feel that if everything is 100% mods should not have to be made.
I do have a 195 degree thermostat ready to install.
A blue wire mod is just switching on the fan when the computer is holding off. It's not that big of a deal for the operating conditions when you need it.
I did some work on my A/C last spring, due to a leak in the evaporator. Also replaced the lines, orifice, and accumulator. Cooling still wasn't very impressive following this work, especially in 110 degrees.
Two weeks ago the system lost its charge over the course of two days. There was fluorescent dye all over the compressor. Replaced compressor, condenser, orifice and accumulator. Flushed lines and evaporator. Following morning outside was a cool 83 degrees when I drove into town and A/C was nice and cool too. Wasn't so cool on the way home at 5pm with 110 deg temps; more like cool-ish. The next day's drive home was barely blowing cooler than outside temps.
Following morning (last Friday) I charged it with a full can of dyed refrigerant and another half can. While it was charging I looked around underneath and saw fluorescent dye on the tranny cooler lines and starter. I recalled a tiny hole I noticed on the top rear of the compressor. I never considered the compressor to have a built-in relief valve, but it makes sense considering the location and amount of the dye, and the quick draining of refrigerant. I started looking at high pressure switches and only one, Santech at Autozone, said "fan function" in the description. I drove to the dealer without the A/C running and got a high pressure switch.
Today was my maiden voyage after the truck sat all weekend. 99 degrees when I left the house (according to the overhead) and was notably cooler than right after the repairs weeks ago, and cooled down much faster with a hotter cab that had been sitting in direct sun. For the first time in a long time I heard the fan running at a stop light. All but the first ten minutes of the trip home were quite cool. Keeping my fingers crossed that I don't also have a leak, but the high pressure switch certainly made the cooling more consistent, and possibly was the problem all along.
And the best part - It was $42 out the door at a local dealer and literally took 10 minutes to swap. WBL has it listed for a whopping $21.84. At that price I'll replace it next time I have to open up the system too.
https://parts.autonationfordwhitebea...OC1kaWVzZWw%3D
