Missing cab corner peace
Old Aug 12, 2023 | 09:41 PM
petrokiller's Avatar
petrokiller
So I just drove my truck today. Get home and look out the window at the weather.
And dadgumit I am missing some roof corner cab trim.
Guess I gotta start looking in junkyards
Old Aug 12, 2023 | 09:46 PM
Kwikkordead's Avatar
Kwikkordead
https://www.google.com/search?q=2000...hrome&ie=UTF-8
Old Aug 13, 2023 | 07:02 AM
petrokiller
Thanks Kwik
Hadn't thought about eBay.
Do these snap or glue on?
Old Aug 13, 2023 | 07:09 AM
Dan V's Avatar
Dan V
The OEM ones use a plastic stud with a tinnerman nut...from the inside.
Old Aug 13, 2023 | 07:28 AM
Walleye Hunter's Avatar
Walleye Hunter
I may be able to send you one. I'll look in the garage later this morning. I guess I need to pull the headliner down to get to the nut?
Old Aug 13, 2023 | 07:38 AM
AubieTN's Avatar
AubieTN
Sir, if it’s not leaking to inside and you can find a replacement piece, I would simply add some clear caulking around the cover’s perimeter and a big glob on top of each nut, then press and hold and maybe use some masking tape to hold it in place until the caulking cures. Least amount of work without disturbing a sealed area.
Old Aug 13, 2023 | 07:54 AM
FordTruckNoob's Avatar
FordTruckNoob
Hmm, methinks I should make a mold of mine before they pop off. Then when they do, I'll just put the mold back on top and squirt bondo/epoxy resin/caulk in to create a new piece.
Old Aug 13, 2023 | 08:10 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
My corner piece started to come loose years ago and I cannot remember how I reattached it, but I think I used flexible epoxy of some sort to glue the fasteners back together. Years later it is still good to go.
There used to be a write-up in the 7.3L PSD Tech Folder with details, part numbers and pictures about this same issue, but I was unable to find it.
Old Aug 13, 2023 | 08:52 AM
CousinCarl's Avatar
CousinCarl
https://www.ford-trucks.com/forums/1...l#post19248597
Old Aug 13, 2023 | 09:03 AM
Sous's Avatar
Sous
FTE Emeritus
Well spotted sir! Thank you for posting the link for Brad and/or future readers.
Old Aug 13, 2023 | 11:12 AM
Wes444's Avatar
Wes444
Crap. Have to remove the headliner. Noticed my passenger side removed itself during our last camping trip
Old Aug 13, 2023 | 11:51 AM
tjc transport's Avatar
tjc transport
i ain't rite
when they loosened up on my 02 i used clear silicone. that has been over 10 years now.
Old Aug 13, 2023 | 08:08 PM
V-22 Osprey's Avatar
V-22 Osprey
I had one fall off my truck earlier this summer, got lucky, it stuck between the cab and the truck cap. Was driving along and heard this loud squeaking, I would have bet anything, the sound was going to be bad!
Old Aug 14, 2023 | 08:11 PM
Brother Les's Avatar
Brother Les
CousinCarl has a great write up to fix his trim piece when it came off. I was able to order one for me from the Ford Dealer, had it in two days. O'reeely mix me up a can of paint to match my truck
Old Aug 15, 2023 | 07:25 AM
WNYPSDguy's Avatar
WNYPSDguy
I tried to order these last year. One was still in stock, but the other side was obsolete if I remember correctly. I ended up going to the junkyard and getting a set and a couple spares. Save the nuts, you will likely drop a couple….Ask me how I know.
