Gear ratio limits
Old Aug 12, 2023 | 07:07 AM
Desert Don's Avatar
Desert Don
Also for the 10.5
https://nitro-gear.com/ford-10-5-5-3...yABEgIJZPD_BwE
Old Aug 12, 2023 | 07:08 AM
rjacobs's Avatar
rjacobs
Originally Posted by ATC Crazy
OP must not be looking too hard:
The rears are more of a problem than the fronts. It looks like in 2011 Ford went to a 37 spline rear pinion from the 35 spline earlier. There were also some internal bearing changes. I can only find up to 4.88 gears with the 37 spline pinion.
But even most of the fronts say 2005-2010... not sure what changed if anything to the fronts.
If you search for 2017+ you wont find much either... again, not sure what, if anything actually changed.
Old Aug 12, 2023 | 09:47 AM
willynilly's Avatar
willynilly
Have you talked to the gear manufacturers? I'm pretty sure I've read on here from those with more knowledge on the front axle, that it's the same D60 that Ford has always used.
no its different. 17+ pinion is short and uses two of the same size bearings. prior was longer with a large and small bearing.
why theres no 5.13 or 5.38 likely boils down to demand. very few people would need such a ratio. for the average joe ( which is most people) ,those high ratios are useless. if they could sell a wharehouse full of them ,they would of made a wharehouse full of them already
Old Aug 12, 2023 | 10:16 AM
jeepontons's Avatar
jeepontons
4wd High
that would be great if they made them for the 2017+ which you’ll find doesn’t go lower than 4.88
Drake12
Feb 14, 2020 02:41 PM
Joe Meg
6.7L Power Stroke Diesel
Jan 18, 2010 05:35 PM
TNtrapper
Dec 14, 2006 08:26 PM
RushN350
Dec 22, 2005 05:16 PM
Broke_Okie
Offroad & 4x4
17
Aug 7, 2005 08:14 PM
