PIP, Computer, or Reisistor Code 212
Old Aug 27, 2023 | 07:24 AM
  #46
manicmechanic007's Avatar
manicmechanic007
Old Aug 27, 2023 | 03:43 PM
  #47
Matthew 300-6's Avatar
Matthew 300-6
OK, the solenoid checks out fine for resistance (aprox. 35ohms) I’ve got .25V at the VPWR (red wire) EVR harness checking to battery ground. If I’m reading the service manual right, I’ve got an open circuit. Is there a likely location where wires get damaged? Is there a way to bypass the harness / loom and supply power from a different source?
Old Aug 27, 2023 | 04:28 PM
  #48
manicmechanic007
Not sure which exact wire you are checking in that 8 pin connector
According to that schematic your VREF should be red at the EVR and brown with white at the EVP
Check them both
Should be 5 volts.
I have no exact place to tell you to look for your VREF short
I have seen bad splices and shorts to ground or short to B+ even
Check around the battery for the convolute tubing to be corroded at that harness
The positive battery cable from the starter relay to the starter used to run with some processor O2 sensor wiring
Check that harness for corrosion
Pull the processor connector with the battery disconnected and test ohms pin
26, 37 and 57 should all have continuity to one another VREF
They, 26 37 and 57 should be infinity to both battery terminals (power and ground)
Be wiggling the harness around looking for the short location while doing those tests
Old Aug 27, 2023 | 05:00 PM
  #49
Matthew 300-6
OK, this is frustrating. I see your post, go wiggle some stuff around the battery (no idea what I'm wiggling) and now I have 7.5V at the Solenoid harness. I can't get it to go away with more wiggling, just a solid 7.5V where before I had .25V.
Is 7.5V enough power for the solinoide? Maybe I'm misunderstanding the manual but shouldn't the voltage be 10.5v or greater? Regarding the 8 pin connector, I realized that I'm not sure that I was thinking right on that so I deleted it above and before I saw your response.
Old Aug 28, 2023 | 11:40 AM
  #50
manicmechanic007
You need battery voltage for the solenoids.
Below about 10.6 volts none of them will work.
The VREF circuit is 5 volts, nothing should really be 7.5
Old Aug 28, 2023 | 01:22 PM
  #51
Matthew 300-6
Engine off, my battery is reading 10.4V. Again, I’m not good with electrical. I would expect the amperage to be low if the battery is low on charge but not the voltage. Is that right?
Old Aug 30, 2023 | 03:36 PM
  #52
Matthew 300-6
DN12 says to install the breakout box (which I don't have). Do I really need a breakout box for that? Why can't I just check resistance at pin 33 on the computer harness and the solenoid harness?
Old Aug 30, 2023 | 04:23 PM
  #53
manicmechanic007
That's exactly right
Read between the lines and backprobe the connectors where needed
In the case of DN12 disconnect the processor and ohm out the wire from the EVR to pin 33
  #54
manicmechanic007
Disconnect the battery before the processor
ironman1952
17
Nov 10, 2021 03:29 PM
Tomget
1983 - 2012 Ranger & B-Series
32
Apr 11, 2015 08:41 AM
1994 f150 4x4
Jul 12, 2012 07:36 PM
cradar69
Nov 27, 2005 03:22 AM
bumpin_BII
Bronco II
Feb 20, 2003 10:41 AM
