Bleeding clutch hydraulics
Hey fellas! I’m going to do the heim joint mod on my clutch pedal and I even found a braided stainless steel hose to upgrade the one I have now. Had a few questions.
I need to pull the master out so I can weld on the heim joint. What’s the best way to get these dang roll pins out of the master and slave? I need to bleed the whole thing as well but I’m worried about stripping the bleeder in the plastic slave…. is my vacuum bleeder the way to do it? I’ve heard bleeding these can be a pain. I’d buy the pre-bled unit but where I have the ZF5 I can’t.
Any pointers would be appreciated!
Truck is an E99 with a ZF5 swapped in. Thanks,
Andrew
Andrew
The following users liked this post:
Dang I should have taken more pics. You basically cut the circle off of the master cylinder push rod and then slide the heim joint onto the shaft. It comes with a set screw but a tack weld is going to hold it a lot better in the long run.
Not sure if the heim will slide onto the pedal pin…. Mine was farmerized so I already had a hole drilled for a bolt. If that makes sense?
Google ‘OBS clutch heim’ and it’s the first thing that pops up. Hope this helps. Thanks again,
Andrew
Andrew
Here is the solution that Timmyboy76 came up with a couple years ago. I never got around to doing this even though I have the parts in a bag in the garage. That seems to be a theme around here for us on the FTE...
https://www.ford-trucks.com/forums/1...l#post16202528
