Catching a ride
Old Apr 12, 2016 | 07:19 PM
timmyboy76's Avatar
timmyboy76
Catching a ride
Well, truck has a date with the flatbed. Post on the clutch pedal gave way, and she(pedal) went to the floor. I've fixed it once about 4yts ago, but guess I need to hone up on my welding skills...
Old Apr 12, 2016 | 07:46 PM
carguy3j's Avatar
carguy3j
You could do this:
https://www.ford-trucks.com/forums/1...c-bushing.html
Old Apr 12, 2016 | 10:49 PM
timmyboy76's Avatar
timmyboy76
^^^not bad. Might have to take a gander at that tomorrow. Got the pedal and post removed from la trucka, but with the move in January, have yet to hook up 220v in garage to fire the welder or else this pig be back on the road
Old Apr 13, 2016 | 12:15 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by carguy3j
Missed that the first time around!
Gotta add your thread to the tech folder revamp that should be getting finished up here in the next week or so.
Stewart
Old Apr 13, 2016 | 09:34 AM
timmyboy76's Avatar
timmyboy76
Instead of going thru the hassle of cutting the bolt, drilling out the pedal arm..etc, what if we got the correct bolt for the pedal hole, then a nut to go with and the correct length of bolt, so then you just add a sleeve over the bolt and thru the master rod. As CHRIS pointed out in that thread, atleast then with sleeve, there would be no binding...(plus, tax weld bolt to pedal arm and not loctite it, to it.. )
Old Apr 13, 2016 | 12:43 PM
timmyboy76's Avatar
timmyboy76
Need to get back on road, so welded post but countersunk hole so more weld to grab. Add insult to injury, that damn rod clip cost 9 bucks, and dealer dont sell just the sleeves that the pedal rides on, on the post/shaft
Old Jun 13, 2016 | 02:21 PM
timmyboy76's Avatar
timmyboy76
***UPDATE**
So, my incompetant welding brothers' skills suck. Tab broke. Going the bolt route this time...damn
Old Jun 13, 2016 | 06:21 PM
Jaime74656's Avatar
Jaime74656
Stewart
Stewart, glad to have a status update, was actually going to PM you tonight for one, I am hunting for other threads to include (I semi split the head unit discussion so I may fire that your way if you want...)
Old Jun 13, 2016 | 06:30 PM
timmyboy76's Avatar
timmyboy76
1/2x3/8 shoulder bolt, m10 washer, 1/2 washer and 3/8 thin nylock nut
Old Sep 10, 2018 | 03:41 PM
timmyboy76's Avatar
timmyboy76
UPDATE
Seem, some members are kicking the idea around of going the "post removal" route..Been 2yrs for my idear and still goin.
Old Sep 10, 2018 | 04:05 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I was going to do this today, but the garage was so hot and I just ended up replacing the clutch assembly.
This is on my winter modification list though.
Old Sep 10, 2018 | 07:41 PM
hydro man 17's Avatar
hydro man 17
Nothing quite like innovation. Especially when it works so well!
My dad was a machinist, he would always look into a way to make a tool the he needed. A friend of mine's father was an engineer. They were always looking for the correct tool to buy, if they could find it.
stangd1909
Sep 10, 2018 11:20 AM
Jeremy Kamutzki
Sep 10, 2016 08:51 AM
PNWguy
Jul 6, 2012 09:08 PM
buddha43
Aug 27, 2010 09:13 PM
dspeer75
May 4, 2009 08:59 AM
