Sponsored by: Auxito
02-motor conversion??
Old Aug 2, 2023 | 09:53 PM
brushtrooper's Avatar
brushtrooper
4wd Low
I have a clean 02 2wd Excab shortbed that I just had the complete front end rebuilt and the rear diff with new gears/bearings. AC is cooold, tires are new with less than 5k on them. Truck has 256k on it. The 4.6 was in good shape, small oil leak. I gave it to my son and after about 8 months he spun a rod bearing. So my plan was to watch for a deal on a truck with bad tranny/wrecked etc with a good motor for a good deal. Then the Redneck in me shows up to the party....I have a good 300 six and C4 sitting in a container...Im a 300 nut and buy them where I get deals. So lets put the 300/c4 in, build brackets and driveshaft. Run wiring needed and new starter switch for the motor if needed. I can weld/fab motor mounts/crossmembers, etc. Id have the driveshaft built. I probably need adult supervision on this idea but i like it. I can always use it on the ranch to feeed cows etc if I have issues with inspection.
Thoughts?
Old Aug 3, 2023 | 12:10 AM
85e150's Avatar
85e150
Another 4.6........
Old Aug 3, 2023 | 07:34 AM
manicmechanic007's Avatar
manicmechanic007
Right, fix that truck with a good 4.6 and buy yourself another 4.9 truck later
Old Aug 3, 2023 | 04:35 PM
Hit Man X's Avatar
Hit Man X
Plenty of good, used PI 4.6s around. Do that.
broncoman1980
1978 - 1996 Big Bronco
Jan 5, 2007 11:40 AM
Jbot
Oct 28, 2006 04:24 PM
rob68f100
Oct 24, 2004 06:46 AM
billybert
Jun 12, 2003 04:19 PM
crazy4Fords
Nov 4, 2002 09:30 PM
