Excessive smoke
Old Jul 11, 2023 | 12:56 PM
bismic's Avatar
bismic
What air intake do you have? If stock, have you checked the filter minder?
Are you using ForScan for reading codes?
Old Jul 11, 2023 | 01:38 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Where did you get the injectors?
Old Jul 11, 2023 | 03:14 PM
Yit96's Avatar
Yit96
I have an s&b filter and just cleaned the filter.
No I used the code scanner in my tuner but I also have a Bluetooth scanner I can use as well
Old Jul 11, 2023 | 03:15 PM
Yit96's Avatar
Yit96
AutoZone, but I've had smoking issues since before the injector change.
Old Jul 11, 2023 | 03:38 PM
Bitterroot Diesel
Former Vendor
What if the AZ injectors aren't any better than what you had?
Old Jul 11, 2023 | 03:44 PM
bismic's Avatar
bismic
Tuners are bad code readers - period.
Also, not all scan tools are created equal.
ForScan will read all codes. Torque Pro is very good also.
Not many others do all that well (except when you get into the expensive choices). Your truck, your call.
For the early engines, it was important for the PCM to "know" what the air flow is. Sometimes aftermarket filters allowed excess air flow with very little pressure loss (ie didn't filter as well). Might be contributing. That said, the MAF should take care of that.
Old Jul 11, 2023 | 06:00 PM
Yit96's Avatar
Yit96
Just used torque pro, only codes stored are P0403, P0405 and, P1000
Old Jul 11, 2023 | 07:30 PM
bismic's Avatar
bismic
What kind of EGR delete do you have?
Old Jul 11, 2023 | 07:32 PM
Yit96's Avatar
Yit96
Not sure. Was deleted when I got the truck. But there is no cooler or valve or anything.
Old Jul 12, 2023 | 08:00 PM
Yit96's Avatar
Yit96
Anyone got any ideas? Could it be the ficm even tho it's still reading 48v?
alliz1986
6.7L Power Stroke Diesel
Sep 27, 2021 01:12 PM
bizzelj
Nov 9, 2016 05:33 PM
brandonlear
Jul 6, 2015 08:46 PM
Saxon
Dec 12, 2012 09:24 PM
topdrive
Sep 8, 2009 09:02 PM
