Sponsored by: Auxito
What is the best oil for a 2000 Ford F150 (4.6)
Old Jun 14, 2023 | 09:51 AM
Al Yelton's Avatar
Al Yelton
Thumbs up What is the best oil for a 2000 Ford F150 (4.6)
With 220,000 miles, the oil light coming oil before the engine is warm and moving for 1/2 mile. I am not sure if she is burning oil.
Thanks
Old Jun 14, 2023 | 10:11 AM
Djosbun's Avatar
Djosbun
Don’t waste your time worrying about the “best oil”. You need to get an oil pressure test gauge (remove the schrader valve at the plug if it has one) and test the mechanical oil pressure.
— Dave
Old Jun 14, 2023 | 10:25 AM
Al Yelton's Avatar
Al Yelton
— Dave
Sounds good. So oil is oil, no matter what I use?
Old Jun 14, 2023 | 12:25 PM
apache84's Avatar
apache84
Id use a 5/30 with that many miles. Brands like Oreileys house stuff has worked just find in my stuff for years. last time I was in a AP store to name oils were almost $12 a quart, screw that I say.
Old Jun 14, 2023 | 12:29 PM
Alweeja's Avatar
Alweeja
3rd Gear
Good to hear….I do not want to “pay” for their advertising
Old Jun 14, 2023 | 04:33 PM
pdqford's Avatar
pdqford
Thanks
Strange that the oil pressure light turns off as the engine warms up.
That's when the oil tends to thin out a bit.
How sludgged up is that well maintained engine?
Old Jun 14, 2023 | 05:09 PM
Al Yelton's Avatar
Al Yelton
Oil was changed two months ago. Looks brand new. The light only comes on when the engine is freshly started. It is only on for 20 seconds.
Old Jun 15, 2023 | 11:07 PM
joendoodle's Avatar
joendoodle
5W30 full synthetic, IMO Ford sacrificed long term reliability by recommending 5W20 to get a better CAFE rating, being confident they will last past the warranty period... note the same engine in fleet models carries the 5W30 recommendation.
I like to know the "Actual" oil pressure, instead of the "Idiot gauge" I call it an idiot gauge because our gauge is actuated by a switch.. If the switch senses the minimum oil pressure the "idiot gauge" indicates "normal", if not it indicates downscale. I have had plans to install and oil pressure sender and gauge in my F150 for awhile, and have never got around to it. But I have tested with a mechanical gauge.
Oil pressure @ idle
I would check yours with a mechanical gauge, If oil pressure is lower than you desire I would consider dropping the oil pan and checking / cleaning the oil pump pickup, however it is more likely the cam phasers / solenoids are the culprit.
Old Jun 16, 2023 | 02:09 PM
Al Yelton's Avatar
Al Yelton
Thumbs up
Oil pressure @ idle
Thaks for the explanation
Old Jun 17, 2023 | 11:35 AM
Hit Man X's Avatar
Hit Man X
Spend more money on a filter than on the oil itself.
Expedition has 5/30 STP syn oil from Autozone. Lobo has some 5/30 and some 15/40 as it was low when I was out and had to top off. Still drives fine.
Leak is at that filter housing adapter gasket.
Old Jun 17, 2023 | 12:31 PM
Al Yelton's Avatar
Al Yelton
personal favorite?
Old Jun 17, 2023 | 12:40 PM
Hit Man X's Avatar
Hit Man X
One year OCI, no leaks, and daily driver? Redline with a good filter. M1 or Amsoil filters usually top tier. Fram's high end seems well made too.
Beaters? Just get whatever is on sale oil wise (all API certified anyway), keep it clean and full. Hell evem Pennzoil YB is great stuff. I usually do six months/5k intervals on my stuff that leaks. One leaks so bad I just do the filter I add a quart every 500mi. Yes, massive leak at pressure point on my 4x4 Suburban's pan rail. Super common but the 5.3 is coming out for a 6.0HO
Check out Bobistheoilguy.com great site. Tons and tons of info.
Old Jun 17, 2023 | 06:56 PM
manicmechanic007's Avatar
manicmechanic007
I would use
Motocraft 5w30 semi synthetic oil
And
A Motorcraft oil filter. FL 820? on yours
I would
Replace your oil pressure sending unit and use a Ford one NOS if now obsolete over the parts counter
Get the part number from them and search Ebay for one
curiousv
1997 - 2003 F150
Jun 17, 2023 08:25 PM
digitalshooter
Modular V8 (4.6L, 5.4L)
Aug 7, 2011 12:45 AM
Habby6543211
Jun 24, 2004 03:48 PM
