Diagnostic Help Please.
Old Jun 26, 2023 | 10:57 AM
  #61
BWST's Avatar
BWST
Got Data?
Dave - need you to add PIDs TCC(%) and GEAR and log a new drive of the truck. We need to see all six PIDs in relation to each other:
GEAR, MFDES(%), TCC(%), VSS(mph), RPM(1/min), TC_SLIPACT(1/min)
Your CSV file just has 4 of these PIDs.
Old Jun 27, 2023 | 10:59 AM
  #62
SC_Dave's Avatar
SC_Dave
Will do. It will probably be the weekend before I have a chance. Thanks!
Old Jul 3, 2023 | 10:23 AM
  #63
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
David sent me another data log file this morning. I have charted the data log and included it below. I have also attached the data log from David and the Chart from the PID Charting Tool.
@BWST might be able to manipulate the TCC% and GEAR PID's a bit better. I ended up changing the FUEL PW trace to GEAR and APP% to TCC% in order to reflect the data points requested.
File Type: csv
Old Jul 3, 2023 | 12:15 PM
  #64
udsuth78's Avatar
udsuth78
Hmm, can't really pick it up from the graph but scrolling through the data I noticed your 2-3 shift takes over twice as long from the time pcm commands it to shift and the shift actually happening. Roughly half a second vs about 1.2 seconds. I don't speak "automatic transmission", still waiting on that particular Rosetta Stone to come out, but I'd guess that is a clue. Not sure if it could be a solenoid thing or a something in that "worlds most insane game of snake" otherwise known as the valve body, but at least there's data here documenting that you're not crazy. Something is actually going on.
Old Jul 3, 2023 | 01:51 PM
  #65
BWST's Avatar
BWST
Got Data?
Good bird's eye view of the data there, Sous, and we can see the TC lock working as it's intended, but not much info on the hard 2-3 shift.
Here's a zoomed in view of one of the runs through the gears. At first glance, it looks normal, with each shift taking about 0.6 seconds once RPM started to drop, which would typically feel smooth, or even firm.
I increased the resolution on the charting tool to see more data points, and noted one of the 2-3 shifts showed erratic RPM. There was also a delay from commanded 2-3 shift to the start of the RPM drop: about 1.3 seconds, compared to 0.4 seconds for 1-2 and 3-OD shifts. EDIT: udsuth78 saw this first!
I noted the other 2-3 shifts in the chart also showed this delay, but most had normal RPM drop. Could this 2-3 shift delay indicate a problem with the solenoid or valve body?
Old Jul 3, 2023 | 02:37 PM
  #66
SC_Dave's Avatar
SC_Dave
So with one of the 2-3 shifts on this test drive I noticed what I will term as a "hesitation" then the hard shift. This is the first and only time I have experienced this.
David
Old Jul 3, 2023 | 04:09 PM
  #67
BWST's Avatar
BWST
Got Data?
That last chart could very well show that hesitation. @Mark Kovalsky what do you think based on the data presented today?
Old Jul 3, 2023 | 05:06 PM
  #68
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It looks like it could be a sticky 2-3 accumulator valve. That could do all of the symptoms that have been shown here. The solenoid does control when the shift starts, but has nothing to do with how hard or soft the shift is.
Old Jul 3, 2023 | 05:53 PM
  #69
SC_Dave's Avatar
SC_Dave
Thanks Mark, So I assume from that my best bet is to take it into a transmission shop?
David
Old Jul 3, 2023 | 06:55 PM
  #70
udsuth78's Avatar
udsuth78
That depends on how adventitious you are. It's not to difficult to tackle yourself just meticulous. Clean is the name of the game in an automatic transmission, that and pay attention how it comes apart(pictures, pictures, pictures). Still beats the shop tanking you to the barrel, and still not knowing if they fixed it or just cashed your check and dumped a bottle of shutter stop in it.
Old Jul 4, 2023 | 08:21 AM
  #71
SC_Dave's Avatar
SC_Dave
Absolutely true. It’s not going to be possible for me to tackle it. I’m three months out from knee replacement surgery and while I’m doing great getting up and down is not so good. Not sure what avenue I’ll take just yet.
Old Jul 5, 2023 | 05:12 PM
  #72
SC_Dave's Avatar
SC_Dave
I really do appreciate all who tried to help me here especially Sous for putting up with my ignorance of ForScan. Thanks very much guys!
David
Old Jul 5, 2023 | 08:33 PM
  #73
RacinJasonWV's Avatar
RacinJasonWV
We wish you the best of luck. Come back and let us know what the shop says and the final fix. Sorry we couldn’t help you fix it at home.
Old Jul 6, 2023 | 06:58 AM
  #74
SC_Dave's Avatar
SC_Dave
Will do. I appreciate the help. Turns out my close friend has a long time friend that has an independent transmission shop so I'm going to take it there. I'll report back.
David
Old Jul 6, 2023 | 08:17 AM
  #75
Sous's Avatar
Sous
FTE Emeritus
That is great news David. As said before, we are hopeful the fix action is swift and cheap.
