autolite 1100 help
Old Jun 11, 2023 | 09:47 AM
lshort's Avatar
lshort
autolite 1100 help
So I just got a 66F100 and it was running off a small can of fresh gas well enough to load and unload from the trailer.
It would not idle off choke so I decided to rebuild the carb.
The problem is that now everytime that I start up the carb floods over.
After several attempts to readjust the float level I finally took the top off the carb, turned it upside down and connected my radiator pressure tester to the fuel inlet and some soapy water shows that the needle valve will not hold any pressure with the weight of the float pressing against it,
I have checked and rechecked for dirt on the needle or seat, put the old needle valve back in and nothing works.
This model of the 1100 unfortunately has a non replaceable needle valve seat.
I also checked my fuel pressure and it is 6 psi.
Anyone got any ideas or do I need a new/different carb?
Old Jun 11, 2023 | 06:58 PM
Christmas's Avatar
Christmas
Get a Holley they are much easier to work on. I find the Autolite/Motorcraft carbs to work when they work, but when something goes wrong, they will give me fits.
Old Jun 11, 2023 | 07:58 PM
6t6merc's Avatar
6t6merc
I suggest you remove the float and examine it for a crack or pinhole that might not be visible to the eye. Clean the float with something abrasive, place it upside-down and allow it to dry. When it is dry, turn it right-side up and look for a leak to reveal itself.
Old Jun 12, 2023 | 04:56 AM
Crop Duster's Avatar
Crop Duster
Sounds like you may actually have an 1101 carb. The weight of the float alone isn't enough to seal the seat. Make sure you have the correct needle the 1100 uses a different needle than the 1101. Look closely at the seat to make sure there aren't any pitted spots in it.
Here is a link to a parts page scroll down to see the different needles. Autolite 1100 and 1101 Carburetor Kits & Parts Catalog (carburetor-parts.com)
I looked at your other thread and that looks like a real clean truck.
Old Jun 12, 2023 | 06:42 PM
lshort's Avatar
lshort
I looked at the seat under magnification and it was pitted, I tried several methods to recondition the seat but finally gave up and ordered a rebuilt carb, Even when I put quite a lot of pressure on the needle valve it still leaked,
I had everything else done that the truck needed to get on the road and when my carb kit came i thought I would be driving in a couple hours or so but I will get there
Old Jun 13, 2023 | 09:59 AM
E T's Avatar
E T
Trailering
I'm also in a battle with my Autolite 1100. I keep chasing down fuel leaks. Fixed the warped accelerator pump cover, now I have fuel flowing from under the bowl. I think it's coming from the throttle rod where it exits the body.
I think I'm done with this thing. Any suggestions on replacement carbs? I tried ordering a Autoline remanufactured through Rock Auto but then they claimed they couldn't find it in the warehouse. Christmas, you mentioned a Holley. Any specific model I should look for? Any other ideas?
Thanks in advance, sorry if I highjacked your thread Ishort.
E T
Old Jun 13, 2023 | 10:09 AM
lshort's Avatar
lshort
My problem ended up being a pitted needle valve seat.
The way that I tested it was with the top off the carb I put a radiator pressure tester on the fuel inlet and even when putting quite a lot of pressure on the needle valve it still leaked.
What I ended up doing was buying a rebuilt from https://www.carburetorcenter.com/ on ebay, it was not the cheapest route but I did not want to put a Chinese built carb on it.
Old Jun 13, 2023 | 11:20 AM
Crop Duster
E T
No one so far has mentioned which engine they have so we have to assume it is one that used a Load-O-Matic distributor. If so your choice in carburetors is limited to one that has a spark control valve in it. This is a replacement Holley 1904. Holley 1904 Universal Replacement Carburetor N1904 (carburetor-parts.com)
Most any local parts house can get a remanufactured carburetor.
Old Jun 13, 2023 | 11:32 AM
lshort's Avatar
lshort
I am not positive what engine I have, not original, I think it is a 200ci 6 out of a mustang.
Old Jun 13, 2023 | 12:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
144/170/200 I-6's: The intake manifold is made as part of the cylinder head.
The 200 is smaller than the 240/300 I-6's these trucks came with. The engine compartment will look larger with the puny 200 in it.
This is a gutless engine to install in an F100. Post a pic of it.
Old Jun 13, 2023 | 12:47 PM
Crop Duster
You need to take a couple of pictures of your engine and post them. I agree with ND that would not be a good engine choice for a truck. I had a 1965 parts truck that someone had super rednecked a 250 I6 into. It had a rod sticking out of the block is how well that went.
Old Jun 13, 2023 | 02:32 PM
lshort's Avatar
lshort
Yep, it has the intake as part of the head
Steves55
Aug 12, 2010 12:59 PM
soundman502
27
Mar 9, 2007 03:40 AM
Plain Old Dave
Dec 28, 2005 01:43 PM
AdamJeff
Jan 14, 2004 09:40 AM
jesse
Jul 28, 1999 12:52 PM
