First Time Fifth Wheelers
Old Jun 9, 2023 | 08:32 PM
Cajunbubba1's Avatar
Cajunbubba1
6th Gear
First Post Here: Wife and I just picked up a slightly used 2022 F250 Powerstroke, glad we didn't wait for a 2023...not sure about the look on that one lol. Anyway going to pick up our new fifth wheel Monday. Just curious what if any mods are recommended for the truck and or fifth wheel.
for some context, the Wife and I have had 2 travel trailers and a class c up to this point. One trailer was pulled with a tundra, 2nd with a 2019 F250. Took a break from the heavy duty trucks when we had the class C. Excited about the Fifth wheel though, its a Grand Design Solitude 310GK, about 35' long.
Old Jun 9, 2023 | 08:39 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
No mods necessarily needed for the truck, but on a F250 you should find out how much your trailer weighs all full of your stuff.
Many here will tell you the F250 is too small, but that just depends on the set up.
Do you know what options the truck came with?
If it has the high capacity trailer tow, then it should be more than enough, if not then it may be a little overloaded depending on the trailer weight.
No matter what, weight distribution in the trailer will be something to pay extra attention to.
Old Jun 9, 2023 | 09:02 PM
CascadeF250's Avatar
CascadeF250
The truck running gear will handle that fifth wheel just fine. The pin weight is what actually could cause a problem. I had a 250 with 2250 pounds pin weight and had to install an extra leaf on the rear springs to make the vehicle set level. The truck actually did great after that. I went with a F350 on my 22. Happy trails with your set up
Old Jun 9, 2023 | 09:05 PM
Cajunbubba1
6th Gear
My trucks payload is 2600 roughly. Its a gvwr of 10400lbs. I know I'm going to be close, but hoping it looks ok.
Old Jun 9, 2023 | 09:06 PM
longhaultransport's Avatar
longhaultransport
Don't forget to open the tailgate.
Visually ensure the jaws are locked around the pin.
Old Jun 9, 2023 | 09:29 PM
Smurf830's Avatar
Smurf830
You will enjoy the Solitude, I just went out with mine, a Solitude 375RES.that we just purchased. LOTS of room. If your get a chance, go visit the Grand Design factory tours in northern Indiana. See if you can schedule a Solitude factory tour (We did). One of the interesting side notes is that they close the factories a little before 2 pm so the Amish workers can go home and take care of their livestock and other chores.
Out of curiosity, what hitch are you using?
Old Jun 9, 2023 | 10:11 PM
Cajunbubba1
6th Gear
Thats pretty cool, I'll have to check that out! I picked up a used B&W Champion, its the oem puck system one, no slider.
Old Jun 9, 2023 | 10:26 PM
CascadeF250
Smile
I’ve had nightmares about forgetting to open my tailgate on the 2022. This is my fourth diesel and the first time I haven’t had a fifth wheel tailgate. it seems no one uses them anymore. We used the fifth wheel the month of March this year and I remembered every time thankfully.
Old Jun 9, 2023 | 10:45 PM
Kameron Rice's Avatar
Kameron Rice
you will be just fine. My dad has my old 2018 f250 lariat ccsb fx4, 3.55 ratio, sterling 10.50 axle, 6.7L. He just got back from a 6k mile trip towing his 2011 montana 3625re. Dry its 12500lbs, 2200lb pin, and loaded it was around 14,500lbs. Its 39.5ft long as well! He has timbrens and he loved it. Pervious truck was a 16 f350 srw ccsb and he loved how the 18 towed much better. Truck like it better to! Till 36k I towed 24k with it alot probably 8k of those 36k miles. The truck Finally got a break!
just timbres, airbags, or a leaf in the rear and you'll be good. If you have 3.31 axle ratio, being it's a 10spd, it is direct comparison to his 2018 f250 6.7L power wise on takeoff in 1st gear. If you have 3.55s you could tow 30k easily with it, there will be no issues at all performance wise.
Old Jun 9, 2023 | 11:31 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Dry hitch shows 2350. Propane, batteries, you and your stuff will have you over. Get some bags.
Old Jun 10, 2023 | 02:15 AM
Bananasfoster's Avatar
Bananasfoster
I have a Grand Design Momentum. You'll love a GDRV. Quality.
I tried Timbrens AND Sumo Springs when I was pulling with my 350 SRW prior to getting my 450 a month ago. Ended up liking the Sumo Springs more. Softer.
Also put a Helwig Big Wig on the rear, which probably made a bigger difference unloaded than loaded since the Timbrens and Sumos Springs provide sway control when loaded.
You might try a set of either if you think you need a little more rear support.
I have two B&W Companions, one puck in the new truck and one in the received turnover hole on the old truck. Be generous with grease in the claws. You'll start chewing those claws up especially if you drive over uneven terrain.
TRIPLE check that you're hitched correctly. I have a buddy that crushed the bed of his Super Duty with his fifth wheel leaving camp due to not being pinned in correctly.
Old Jun 10, 2023 | 07:30 AM
IADiver's Avatar
IADiver
I have a '22 F 250 and pull a 34' Cedar Creek. I put the lower TorkLift Stableloads on it (free test kit). Didn't like the ride and how they contacted the springs. I went with the Road Master active suspension set on the 1300# setting, also don't need sway bar with the RAS. Pulls like a dream (except for the pin box). I use a gooseneck adapter but going to either a Goosebox or Gen-Y. The truck actually pulls it better than my friends 350. Now I did throw airbags on it as I put a 1.5" level on the front (couldn't stand the low front end unloaded). The bags bring it back to just above level at 40 psi. and smooth the ride. I can fine tune the ride and height between my 5th, and my work trailers. I run 35" tires 3:55 gears.
Old Jun 10, 2023 | 08:58 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
Consider airbags for the F250. Try it with out and then YOU get to make the decision of if they are needed. I also used a slider with my short bed but found out it's worthless if you don't slide it to the maneuver position.
Old Jun 10, 2023 | 09:12 AM
Back2Gas?'s Avatar
Back2Gas?
I had to lift my trailer by 2" since the new truck was 2.5" taller at the bed height than my old truck. It was 4" taller at the bed rails...
Old Jun 10, 2023 | 09:30 AM
senix's Avatar
senix
take the truck to the cat scales with the hitch and family and all that you will have in the truck with you.
See what it weights and then take your GVW minus the actual weight and see where you stand.
See how much room there is according to your RAWR and FAWR and tires too at max PSI. Make sure those tires are E-rated tires.
Then compare that against the trailer GVW. Ignore the manufactor pin wt and what everelse the saleman says. Use the GVW and factor 20% of that as king pin wt which will be payload according to the truck.
See how that matches up with what is available.
