First Time Fifth Wheelers
Old Jun 13, 2023 | 12:01 PM
  #46
rufushusky's Avatar
rufushusky
Originally Posted by OverheadCram
It was not the same company if there was any confusion. I have American Commerce for my personal and have had a handful of others over the years for my commercial. Never did I have my personal insurer as my commercial insurer for cost reasons so I have no idea if that provision that they practice by would have carried over to a commercial policy.
I figured that would be the case, still boggles the mind the commercial policy wouldn't call out GVW. I guess you can figure out what provider had better underwriters.
Originally Posted by CLJDieseltech
When going from my King Ranch to the stripped down Lariat....
As someone who has manual seats in his XLT, I can't help by chuckle at a the idea a Lariat is stripped down but I guess it is relatively speaking. Sorry a little OT.
Old Jun 13, 2023 | 12:04 PM
  #47
acdii's Avatar
acdii
Originally Posted by Ry Guy
IADriver is probably referring to the 18" tires, where the 18" all-terrain tires result in ~200lbs higher GVWR on the sticker than the 18" all-season tires for the same truck (e.g., 11,100 lbs GVWR vs 11,300 lbs GVWR for a gas F350 CCSB).
Correct. GAWR is based on the tires on the door sticker. The 200 pounds could be the difference in weight ratings between the different tires.
Old Jun 13, 2023 | 12:24 PM
  #48
OverheadCram's Avatar
OverheadCram
The difference you are referencing here is an actual difference in the tires themselves. A/T 18" tire is a 275 series while the A/S 18" tire is a 265 series. The 265 size tire has a lesser weight rating altogether.
Old Jun 13, 2023 | 12:56 PM
  #49
CLJDieseltech's Avatar
CLJDieseltech
Haha yeah man its rough, I dont have a sunroof, no upfitter switches, no garage door opener, no cab lights, no 360 cams...I thinks that about sums it up. Some of that may have been due to the chip shortages.
Old Jun 13, 2023 | 01:16 PM
  #50
OverheadCram
American Commerce has been by far the best priced insurer for my personal policy. Now youd think with the company that has the better underwriters and denies claims under circumstances other insurers would pay out that they would have the lowest commercial price as well. When I was in business I would of course requote annually and American Commerce commercial insurance was always double the price of all others.
Old Jun 13, 2023 | 08:38 PM
  #51
IADiver's Avatar
IADiver
I understand that, but the tires change the GVWR..... And no they were both 275/70/18.
Old Jun 14, 2023 | 09:56 AM
  #52
DPelletier's Avatar
DPelletier
I don't know why Ford would change the GVWR based on tires; tires should only change the GVWR if they were the weakest link and I don't believe they are in most cases. IIRC, the typical LR E OEM tire is rated at 3415 lbs max load or 13,660 for four making them more than enough for any SRW GVWR. Or to put it another way, for the tires to be the limiting factor they would have to be rated at less than 2,800 lbs (single). The Michelins on my truck are rated at 5195 lbs max weight single so wouldn't be a limiting factor unless GVWR was over 20,000 lbs...
Dave
Old Jun 14, 2023 | 10:08 AM
  #53
IADiver's Avatar
IADiver
Dave
Well, I guess the tires play a big factor into the weight rating. When I ordered my '22, they mistakenly put the AS tires on the order, when I corrected it to the AT tires, the order showed it gained 400# GVWR....
Old Jun 14, 2023 | 10:39 AM
  #54
DPelletier's Avatar
DPelletier
I don't question your experience and observation just noting that it makes no sense as I believe all tires used on a Super Duty are rated at far more than any GVWR or GAWR used. The tires on my F350 DRW have a combined rating of 22,030 lbs compared to a GVWR of 14,000. The same tires on an F350 SRW would have a combined rating of 20,780 lbs vs. a GVWR of 11,400.....tires don't appear to be even close to the limiting factor.
Dave
Old Jun 14, 2023 | 11:08 AM
  #55
Ry Guy's Avatar
Ry Guy
The 2022 AS and AT tires are different dimensions. The AS tire is an LT275/65R18 and the AT tire is an LT275/70R18. Check the brochure/order guide/build & price tool/window sticker and you will see. According to Ford, the load index on the AS tire is 123 (3417 lbs), whereas the load index on the AT tire is 125 (3638).
It's all just games being played on Ford's part. Pay us $300 more for AT tires and we'll have someone write a bigger random number on your door sticker.
Old Jun 14, 2023 | 01:48 PM
  #56
johndeerefarmer's Avatar
johndeerefarmer
Add air bags. In '20 Ford softened up the springs. My '20 F350 rides way better empty than my previous '16 but with a load it's way to bouncy on the soft springs.
Old Jun 15, 2023 | 09:03 AM
  #57
Back2Gas?'s Avatar
Back2Gas?
Does not sound random at all, almost pound for pound. And $300 is better than buying new tires for a new truck, so get what you need when you buy the truck...
Old Jun 15, 2023 | 09:28 AM
  #58
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
Originally Posted by Cajunbubba1
My trucks payload is 2600 roughly. Its a gvwr of 10400lbs. I know I'm going to be close, but hoping it looks ok.
First Post Here: Wife and I just picked up a slightly used 2022 F250 Powerstroke, glad we didn't wait for a 2023...not sure about the look on that one lol. Anyway going to pick up our new fifth wheel Monday. Just curious what if any mods are recommended for the truck and or fifth wheel.
for some context, the Wife and I have had 2 travel trailers and a class c up to this point. One trailer was pulled with a tundra, 2nd with a 2019 F250. Took a break from the heavy duty trucks when we had the class C. Excited about the Fifth wheel though, its a Grand Design Solitude 310GK, about 35' long.
The 310GK has a published pin (Hitch) weight of 2350 lbs. That means with you and your wife sitting in the truck, and the trailer connected, you will be over the GVWR of the truck.
I learned also, when shopping for 5th wheels, that my 250 was inadequate for most 5-ers.
You should have bought a 350.
Old Jun 15, 2023 | 11:51 AM
  #59
BEBosworth's Avatar
BEBosworth
I would be skeptical of advertised pin weights. Jayco says my 2023 355 is supposed to have a dry pin weight of 2360. That's not realistic given the dry weight of 12,845 and max weight of 15,200. It squats my 2022 350 CCSB SRW a good 3-4" and we don't have a washer/dryer and don't travel with any liquid in any of the tanks except for the 5 gal drinking water jug.
Old Jun 15, 2023 | 12:15 PM
  #60
DPelletier's Avatar
DPelletier
Yep, dry trailer weights and dry tongue weights are theoretical and bear little basis on what a trailer will actually weigh, ready to camp, in the real world - always better to go with the GVWR and use 12 - 15% for bumper pulls and 20-25% for 5ers. My travel trailer has an advertised dry tongue weight of 720 lbs; actual measured tongue weight ready to camp is 1,275 lbs.
Dave
