One other major issue that 5th wheels have is you have to watch your height clearance. Not so much with TTs. My Jayco is almost 13’ and on more than one occasion I’ve had to back out of trouble.
I’ve seen local underpasses way under 14’ that weren’t marked, gas stations too (lost an AC to one of those in Jacksonville that was miss marked by 6”).
About the only suggestion I have is to always do a tug test on the hitch before you bring your front landing gear all the way up. That way if you don't have the jaws locked when it comes out it will land on the gear instead of your bed.
The Solitudes are well built 5th wheels, but because of that they are heavy. It appears that the 310 GK is the smallest Solitude, so that will help some, but IMHO the Solitude line is mostly dually territory.
I pull a Reflection 337 RLS with my 2017 F350 CCSB 4x4 Lariat Power Stroke with a GVWR of 11,500 lbs. I am nearing my Cargo Carrying Capacity of 3426 lbs pulling my 5th wheel loaded for camping.
Sorry for the bad news, but I want to see people be safe on the roads.
That is just plain inaccurate information, like much of the thread. The 310GK is 12,100 empty with 2350 on the pin. My srw is rated for over 4100 lbs in the bed and 16k towing. It will easily handle this trailer. Anybody paying attention knows there is precious little difference between the 250 and 350 and that running 80 psi in the tires with some airbags to counter the sag, the OP's truck will handle it just fine. The numbers on your stickers are not the be all end all of being "safe" on the road, sorry for the bad news...
I pull a similar sized Jayco Pinnacle 32RLTS but it is a little heavier than the GD 310GK. The brochure pin weight is around 2500 pounds but after adding a washer/dryer in the front closet, a Reese Goose Box and fully loaded for a month long trip to the Colorado Rockies my pin weight grew to 3120. I only fill my fresh water tank to about a third when traveling. Adding stuff will increase the pin weight, obviously. I have a long bed F350 and with it's 12,400 GVWR I have some cushion. It pulls the Pinnacle very smoothly and I feel no need for a dual. I do believe, however, that the op will be pushing the weight limit of his truck, payload wise. I'm far from being a weight police type so I think if he manages his weight distribution he can probably keep it close to what the factory says his truck can handle.
I agree with RidgwaySD. The only difference between an F250 and F350 is the rear springs and the recommended tire pressure setting. My 250 has a payload of 2639Lbs. I'm a fan of being legal for liability, you should be able to manage a legal pull with your setup. I just ordered some Timbrens for my setup as I'm right at 2290Lbs with my Refleciton 28BH.
There is NOTHING illegal or anything that would make you "liable" if you exceed the sticker number for payload. That lie is told over and over and over on the internet... Sadly some believe it. Next someone will chime in with "but muh insurance!!!" They don't care either...
My uncle and I ran a 2018 ram 4500 and a 40' mini float for united vision for 3 years down here on the gulf coast of Louisiana. When I reference legal, I'm just used to watching weights on the commercial side. The truck would regularly have to go through weigh stations, especially out of state. If we were over weight on any axle, its 100% ilegal and we would pay for it. Sadly it happened more than once. I'm sure on the private side of things its not a big deal.
I think the only time it would become an issue is if and when you have an accident. If you are found to be over the stated limits, your insurance company will not cover you and you pay for everything. Forget the part about possibly endangering those driving around you.
I have seen this happen to a family member, not a myth.
States right in my insurance policy that coverage is void when exceeding manufacturers GVWR. Exceeding the number on the payload sticker is just about guaranteeing +/- 100lbs you are exceeding GVWR.
I even posted the page right out of my insurance packet and funny thing how many of the users that were 100% positive they were right never came back to that thread after my post. One even in this thread still denying it.
The payload sticker refers to the tires that come with it. If you have 2 identical trucks with different tires, the sticker will be different. Mine went up when the order was changed from All-season to All-terrain.
